Old 04-06-2015, 01:34 AM   #1 (permalink)
silverbullet - '99 Honda Civic HX
New guy w/ HX
whats up! my name is Jonathan. I am a total noob in the ecomodder world. I just got myself a nice clean 1999 civic HX 5 speed. Bone stock. Is this a good car for ecomodding? i sure hope so.
if you can give me any advice or anything that would be nice i really dont know what i have other than it has eco vtec and lean burn i think. no idea how to tell when its lean burning though!
so far i have felt a small performance gain at about 2500k but only sometimes i feel it.
oh wow i cant post pics yet haha thats dumb
ill get pics up soon.
Old 04-06-2015, 02:01 AM   #2 (permalink)
This is my gas guzzzzler
Old 04-06-2015, 09:22 AM   #3 (permalink)
Welcome to the site. The HX is a great car for mileage. You'll be able to do real well with it. Check out the hypermiling tips link up top as well as the modifications list for ideas on what you can do with it. I'd recommend getting your tires aired up and getting some form of instrumentation so you can see what kind of mileage you're getting with feedback on what you do.
Old 04-06-2015, 09:43 AM   #4 (permalink)
hey thanks! what are my options as far as an instrument to monitor it. I dont use. I run tuner pro rt on my truck.
Old 04-06-2015, 10:00 AM   #5 (permalink)
Scangauge, ultragauge, bluetooth OBDII adapter and a smart phone app. Those are the most popular, but there are others.
Old 04-06-2015, 05:11 PM   #6 (permalink)
Hiho, Silver!
I bought an HX in October of 2,013 based on what I read on here and love the car! Honestly, one of the best modifications is Fumoto Valve | Qwik Valve™.
The HX (and EX) have aluminum pans. I think they are thicker than the steel ones, but they are only rated for 36 ft-lbs of torque, instead of 40, and oil change kids like to use impact instead of torque wrenches. When I changed my oil for the first time, there were aluminum threads on the steel plug, it would not tighten properly, and leaked, so I replaced the pan.
As far as instrumentation, MPGuino seems to be the best for the HX, because that car has lean burn, standard MPG gauges only estimate fuel use based on air flow, and lean burn uses less fuel, but more air, so other MPG gauges would show your economy dropping, instead of improving. The MPGuino is not something you can simply plug into your car, you need to build and install it, so I still do not have one. I originally went with UltraGauge OBDII Scan tool & Information Center, $70, plus shipping ($7.85 for me), with a $9 rebate. Some users prefer ScanGauge MPG gauge: improve your fuel economy - EcoModder.com, which is $150 through this site, shipping included.
Many users download smartphone apps and purchase OBD-II bluetooth dongles. Here is the one I ordered: Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
This is the cheapest one on Amazon: Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Automotive
This is the mount that I purchased: http://www.amazon.com/Universal-Smar...hone+car+mount
Torque is pretty popular. I use CaroO Pro (Blackbox & OBD), but I want a dash cam.
One last thing to know, many of us have needed to replace oxygen sensors, $400 from the dealership, and aftermarket ones do not work. Baltothewolf shared this http://www.amazon.com/NGK-24300-Oxyg...ef=mp_s_a_1_19 and said it was $120, but it was $143.10 when I checked in October, and $244 now. I bought one through NTK 24300, $175 plus four dollars to ship. It just arrived today. I have been trying to figure out the rest of my life, so I have not installed it yet, but it is extremely simple!
Old 04-06-2015, 08:12 PM   #7 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Welcome to the site, that's a clean hx you've got there. You should start out with basic maintenance like spark plugs wires cap and rotor and inspect the timing belt for wear
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
Old 04-06-2015, 10:10 PM   #8 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Make a garage entry to track mileage and mods!!
Old 04-06-2015, 11:24 PM   #9 (permalink)
Thanks for the compliments! I will have to check out all those links, thank you.
Timing belt and water pump have less than 10k on them, i checked belt and it looks new.
I got started working on it today, so i went to the honda dealership for everything. I got full synthetic 5w30 honda oil & filter, MTF new formula, air filter and crush washers. I wanted a fuel filter but they were all out of stock.
The old man i got the car from i think only ever had the timing belt done and some light general things done at the dealer. Everything is honda down to the blue coolant and i plan on keeping it that way because my last rusty civic wasnt even a honda anymore, it was more like a duralast pos.
I guess ill make a build thread even though i don't plan on doing anything crazy.
I do have more questions: What are the best tires for MPG? doesn't some company make fuel saving tire tread design?
I think when its cold i can hear a faint exhaust leak so i must check that out soon. isn't it common for the manifold to crack on honda's?
what bluetooth obd2 thingy do you use for an iphone 6?
How did you figure you needed a new o2? Did it show a code?
Old 04-08-2015, 06:30 PM   #10 (permalink)
5 pin sensor
Most of the exhaust manifold cracks occur around the primary oxygen sensor on the exhaust manifold around 180k miles regardless of vehicle. Cast iron seems to have a certain amount of heat cycles before they stress and crack.
My hx cracked at the o2 sensor and would only trigger a check engine light when the car was running and the hood was popped
You should also clean out the egr ports, there is a write up around here somewhere
OG lean burn member
My civic thread
