I thought that the new Bug had a Cd of 0.45? The curve in the rear is way too steep. I doubt it has attached flow as far down the back as the picture shows...
Welcome razordave. The New Beetle has pretty poor aerodynamics as you are aware. The biggest problem is the rounded roofline leading into a too steep back glass. I am including a drawing from another thread. It shows attached flow all down the trunk. What it doesn't show is the two counter-rotating vortexes coming off the C pillar. That is where much of your drag comes from. I think your Kammback is a good start if you can make it strong enough for everyday use.
FWIW, I tuft tested my windshield and the air flowed down and forward where the wipers are. I don't think you will notice much difference by covering the cowl or removing your wipers.
