Old 05-19-2012, 11:33 AM   #11 (permalink)
Originally Posted by Miller88 View Post
Gas explodes, diesel burns. They really have to do some neat things to switch back and fourth I bet.
You should read about the technology a little more carefully before commenting.
Old 05-19-2012, 04:30 PM   #12 (permalink)
...beats walking...
...lookup the definitions of:
CONFLAGRATION - (burning rate)
DETONATION - (explosion rate)
Old 05-21-2012, 09:49 AM   #13 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Modern direct injection is already doing most of what is good about diesel injection and a multi air type valve train can get rid of the throttle plate and loss from creating engine vacuum. The only thing different they are trying to do is get rid of the spark plug and run the compression a bit higher. Mazda already has compression ratios cranked up pretty good and likewise for the eco boost type of engines coming out everywhere.
Old 05-21-2012, 12:16 PM   #14 (permalink)
...beats walking...
...since engine "efficiency" is a function of CR, increasing CR is going the right way, however, eliminating spark-ignition is / has been very difficult proposition because of the vastly different burning characteristics & rates of gasoline and diesel fuels. That's *why* HCCI engines commonly employ both SI and DI -- SI (spark-ignition) when the engine is under heavy loads and high engine speeds and DI (diesel-ignition) during light loads and moderate engine speeds.
