Old 04-10-2012, 06:57 PM   #1 (permalink)
New guy with old stuff
I have been looking at posts on this site off and on for awhile now. It's very cool to see the different approaches people take to get better mpg. I've tried the best I could on my own to get good mpg on my cars, but I want to get a little more extreme. I have a '01 Jetta 1.8t for the daily (wife's car), and a bunch of classic cars. I want to know if there are anyone on here that have tried things to get better mpg on old cars. I know I could go out and buy a 3 cylinder Metro and go from there, but I like old cars. I used to own an '87 CRX Si, and a '95 Civic Si hatch and they did decent on mpg, but they weren't for me.With old cars I don't have car payments, I do all of my own work, I get to teach my kids how to work on cars, the value usually appreciates, and I get more enjoyment out of them.
My next project is going to be a '50 Chevy 2dr Fleetline. Right now I'm looking at swapping the 216 with a 3OTT to a 250 with a 5 speed and a Nova rearend. This might get a GM TBI and a megasquirt conversion too. I think I can get mid to high 20's out of this swap, but if there are better ideas for better mpg and drive-ability, I'm all ears! I was thinking a little bit about modern engine swaps too. Something like the Colorado 5 cylinder with a 5 speed, or maybe even the Colorado 4 cylinder. i want to be able to do 75-80 mph TOP SPEED (could be higher), and I want to get max mpg. Anyone done anything like this?
Before anyone tells me this is a bad idea....I know it won't win any contests. It's not aerodynamic, it's heavy, it costs a lot to maintain and work on, etc... I know. Right now the engine is already cracked, and it's getting a swap either way. The rearend and trans have to go because of the torque tube, so I have a blank slate.
I'm looking forward to hearing ideas, and letting everyone know how my project goes. This fleetline will end up being my daily... except for when I'm riding the old Cb450.
Old 04-10-2012, 08:21 PM   #2 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
That sounds like a cool idea cant wait to see some pics of your project. I love the idea of modern tech into old school cars. Do you have a plan for fuel econ goals? Or is 20mpg your goal?
Old 04-10-2012, 08:29 PM   #3 (permalink)
A 4 cylinder and manual transmission would give all the power you need and have a better chance at hitting your mpg goal.
Old 04-10-2012, 08:31 PM   #4 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Welcome aboard, and as a person who loves the old school, you get bonus points! With a decent amount of room under the hood ( at least lengthwise ), I would look into a couple of things.
Since you are not out for killer speed, and maximum economy, the key would be maximum bottom end torque and nothing torques better than diesel. To keep it 6 cylinders and kind of small, a Mercedes 3.5L inline 6 turbo diesel or the 3.0l twin cam diesel out of the 300 would fit nicely. Going bigger, the 5.9 Cummins would do great, but they are kind of loud in mechanically injected form; the common rail units are pretty quiet. Either way, it'll move that boat down the highway and do 30 mpg or better with a stick and some tall gears.
Gas engine wise, the Atlas engine is not bad, but with all that valve area not great on bottom end torque. You want to cruise, and 2 valves per cylinder and smaller ports will get the job done. Either that or cam those engines differently so that the power is more biased to the bottom end.
That later model 250 inline 6 with EFI is a good start in keeping with the old school flavor, but I don't like the cylinder head. Sissell can do some things with that one, or if you feel like spending some money, get one of those Sissell aluminum heads, a bottom end torque style cam and multipoint EFI. Has a modern fast burn chamber, so that will help with the mpg. Smooth and silky power with some duals running Smiths out the back.
Out of the box thinking: GM 4.8L LS motor, all stock, 5 speed OD, truck intake manifold and EFI, tall gears in the back, carefully tuned. These iron motors can be bought for no money with a lot of life left in 'em and since they do great in the trucks they came out of, your Fleetline will be easy.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 04-10-2012, 10:12 PM   #5 (permalink)
I think a realistic goal would be about 25 mpg. If I could get 30mpg without sacrificing a ton (drastic weight reduction, no accessories, unattractive exterior mods, etc..) then I would be even happier. I was trying to see if anyone had swapped a 4 cylinder into an old car, but I haven't seen it yet. I saw an old mustang online where a guy swapped in a souped up 2.3t and claims around 30 mpg and tons of power. I just don't know how much I believe when it comes to his mpg claim. If it's true, then he's got one of the coolest mustangs out there.
I was thinking about an LS swap too. The 5.3/4.8 engines are cheap and easy to find, and there is a lot of aftermarket support for them. I have heard of trucks getting low 20's on the hwy with them, but I could spend less money with the 250 swap and have the same mpg if not more (I would think the 250 with a worked head and TBI would get a little more).
The Atlas motor (4, 5, and 6 cylinder) all look very appealing. They have great power, but looking at the mpg numbers for the vehicles they came out of, I'm not impressed. I would like to know what modern engine (preferrably GM) have decent power and great mileage.
I like the idea of the Mercedes diesel... Kind of reminds me of a car I saw online. It was an old '50 chevy fleetline (hmmm...) and the original owner had made a bunch of mods and installed a 4 cylinder perkins diesel. He claimed 35-40 mpg (must be nice!). I talked to the guy who was selling it a couple years back and it was COMPLETELY rusted out. I doubt it performs very well, and parts are probably tough, but it's soooo cool! I would love to build something comparable with maybe a more modern diesel,and a 5 speed trans (well anything with a good OD).
Old 04-10-2012, 10:20 PM   #6 (permalink)
There's an Edsel here with a turbo 2.3. If you are happy with low 20s then you can put just about anything in there.
Old 04-10-2012, 11:08 PM   #7 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
A 6cyl. '65 Mustang comes to mind. I had a notchback 3spd. manual that returned
30mpg. stock at 55mph.
With the right gearing, an early Nova might do well also.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 04-10-2012, 11:16 PM   #8 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
as larry said,
it's all about the gearing.
A 7 speed auto with the right rear end and you are off the the races.
I would love to see a VW TDI in a classic. THe tdi gets great reviews and should be able to move a lead sled along at a reasonable pace.
SO much aftermarket for the tdi also.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-10-2012, 11:41 PM   #9 (permalink)
Has anyone taken a VW TDI motor and mounted it to be rear wheel drive and maybe even installed it into something a little older? lol. That is a cool engine, but everyone knows it too. The MB engine seems to be a lot easier to find but I think parts would be $$. Which MB engine would be a good choice?
Old 04-11-2012, 08:24 AM   #10 (permalink)
There have been rear drive TDI conversions. If you go to TDIClub.com a guy put one in a Jeep Liberty.
The engines that I was thinking about are the MB OM606 ( twin cam, 24 valves, non turbo or turbo I6), the OM 612 ( the 5 cylinder they used in the Sprinter vans ), OM603 ( sohc, 12 valve, mechanical injection 6 cylinder ), or the infamous OM617 ( 5 cylinder, IDI, turbo or non turbo ).
You mentioned Perkins diesels. Parts are not that bad to get for those things since there are a lot of boats and industrial equipment still running them, and people know how to get more power out of them.
Or, if you like the noise, you could put a baby Detroit Diesel in ( 4-53, 3-53 ) with a T5 5 speed like this guy did in his Ford pickup :
or this one
Aw heck, why not? It'll only piss off the neighbors!
And they get near 30 mpg with them.
