Old 03-29-2012, 08:03 PM   #21 (permalink)
E300D - '97 Mercedes-Benz E300 Diesel
As long as it isn't totally blocked and the radiator fan can turn on and suck air through you'll be fine. You just don't want the fan running much. Its pretty easy to just use a 12V bulb or something to see when the fan is on or not. From there you can adjust the grill block.
That's a great suggestion, thank you. This weekend I hope to start tackling some of these projects. I'll post pictures when I'm there.
Old 04-20-2012, 03:31 AM   #22 (permalink)
From what I have seen through out the forum, potential is there between hypermiling and a full aerodynamic make over to double the stock mpg. Every little bit helps.
Old 10-01-2012, 01:58 AM   #23 (permalink)
JoeBob's Avatar
Former Barbershop Sign - '91 Geo Metro Funky old car edition
Last 3: 42.15 mpg (US)
Oklahoma Rust Bucket - '83 Cadillac Eldorado Stuck in gridlock on the 405 suspension
Apologies in advance for dredging up an old thread...
...but 35mpg is doable in a 300SD. I usually run between 25 and 30mpg, but I have on a couple occasions hit 35 mpg.
