Old 04-08-2016, 12:49 PM   #1 (permalink)
tuning forum? new old car. where to start?
I started driving my '89 Firebird again. 5.0L V8 automatic, 2.73 gears. It gets 14mpg currently in a 30 mile commute (one way). I want to try to improve that. Where should I start? I was thinking to switch from throttle body injection to tuned port injection with an aftertmarket ECU.
Thanks
Old 04-08-2016, 12:50 PM   #2 (permalink)
There must be something wrong with it. My pickup does better than that.
Old 04-08-2016, 01:07 PM   #3 (permalink)
I could believe 14 mpg in a commute in Los Angeles.
regards
mech
Old 04-08-2016, 01:23 PM   #4 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the rear ratio should work for better gas mileage than 14mpg on the freeway
Gas Mileage of 1989 Pontiac Firebird/Trans Am
EPA got 24 on the freeway, 15 in town.
What is the speed/mph of the commute?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-08-2016, 01:25 PM   #5 (permalink)
mcrews's Avatar
if your average is 30-35mph, there is not a lot you are going to do to increase that number very much.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-08-2016, 01:25 PM   #6 (permalink)
mcrews's Avatar
btw, WELCOME!!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-08-2016, 06:55 PM   #7 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Do you have a smog pump? I'm not sure if ditching TBI will help you much, but the smog pump may be a fuel waster.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 04-08-2016, 09:35 PM   #8 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
If you are going to go through the headache of a TPI swap you might as well go for LSx swap with a cheap 4.8 and ls1 intake to clear the hood. Then with something like HPTuners you have tons of tuning options.
I agree that you should be getting better than 14 unless it's a hard city commute. Auto or manual trans?
Edit: I noticed you are in LA. LS swap trying to get through inspection might be more hassle than it's worth. Will the car have to be recertified if you go TPI or will you just be arrested immediately for tampering with a cars emissions system?
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 04-08-2016, 11:48 PM   #9 (permalink)
LA, not lower Alabama?
