The key thing is not overdoing anything beyond your comfort level.
It has been mentioned many times on here that 5-7 extra psi will help a lot without
losing tire wear. A balanced line also is the ride quality. You don't want to go so high to be waring out shocks, struts, early.
Every veh. has different feels, so oranges to apple comparisons are difficult.
You just need to experiment this for yourself.
Welcome! Plenty of info to be found here.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
