Old 09-06-2011, 01:05 AM   #1 (permalink)
Malibu E85 - '11 Chevrolet Malibu 2LT
90 day: 16.17 mpg (US)
Race car - '98 Chevrolet Camaro
90 day: 3.54 mpg (US)
Malibu Gas - '11 Chevrolet Malibu 2LT
90 day: 26.11 mpg (US)
New here
Just bought a 2011 Malibu 2.4L A6. Hoping to learn some new tricks.
Old 09-06-2011, 11:01 AM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.
Looks like you'll need them.
16mpg is an awful lot of gas or even E85 for a newly bought 2L engine.
Fuel Consumption usually goes down a bit after one gets used to a new car and the car gets bed in, but still...
You state "lots of idling" in your fuel log.
Cut the idling time, as it's wasting gas going nowhere.
Keeping a fuel log and joining an eco-driving forum are good for improving your mileage
Much depends on how you drive, so there's lots to gain there as well.
Read through the hypermiling tips, and see what you could do to improve the mileage.
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
Slowing down, and looking further up the road (i.e. don't accelerate while you may have to slow down or stop further down the road) can get marked improvements in Fuel Economy.
As it's new you might not want to modify the car - yet - but one easy mod is to increase the tyre pressure.
You can do it gradually to get used to the harder ride, but you could go to max. sidewall pressure right away and see what that gives. The ride will get harder as tire pressure is increased, but back off a bit if it gets bouncy. When starting to use higher inflated tires, keep an eye out for uneven wear (Though for me, higher pressures evened out the previously uneven wear on the shoulders.)
65+ Vehicle modifications for better fuel economy - EcoModder.com
A grille block (usually upper grille) is another easy mod, and can be done stealthily if desired.
Keep an eye on engine temps when blocking the grille.
Good luck !
Old 09-06-2011, 11:32 AM   #3 (permalink)
Thanks for the tips.
I am running about 40PSI.
My problem is me and my wife drive the same car. I have been trying to convince her to try to get better MPG. This last tank while she was driving, she set in line picking up the kids a school and let it idle each day. Also During a softball practice 2 times this week she watched the practice in the car with the AC idling. 16 mpg looks awsome to me compared to what we were getting in our Dodge Ram which was 6mpg or less. I know I can get way better than 16 because with only me driving I can get in the mid 30's. My main thing right now is getting her on board.
Old 09-06-2011, 11:54 AM   #4 (permalink)
...beats walking...
...the GM 2.4L engine has Spark-Ignition Direct-Injection (SIDI) which should get quite good milage when 'hyper-mile' driven on the highway at light loadings.
...my '09 Vibe has the smaller 1.8L engine with SIDI (4-speed automatic) and I get excellent 40+MPG at 65 mph...but only with A/C off! Turning the A/C causes MPG to drop like mad.
Old 09-06-2011, 02:06 PM   #5 (permalink)
How do you get those things in your sig that tells your car and MPG?
