Old 02-06-2014, 05:14 PM   #11 (permalink)
A bigger exhaust would probably help on a turbo diesel. I don't think it will on an N/A diesel. On a N/A you want proper exhaust scavenging. Enlarging the exhaust will likely kill low rpm torque as it would on an N/A gasoline engine.
BTW, congrats on the car! It looks to be in great shape for its age.
The Following User Says Thank You to Daox For This Useful Post:
Cobb (02-06-2014)
Old 02-06-2014, 05:49 PM   #12 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Not true on the old D rabbit - I participated in the 90'es in ecomodding just that car, and a bigger exaust with more free flow gave better mpg, both on the Dyno and in daily driving. I dont know why though - but it did....
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 02-06-2014, 07:42 PM   #13 (permalink)
What ever you do retorque the head bolts. Ive seen many diesel vws need a head gasket because the owner never followed the manuals requirement to have the head retorqued every so often.
Also if you are looking for MORE POWER examine the injector pump. There are a few screws you can turn to adjust things. You can limit rpms, idle and max amount of fuel injected into the engine.
Old 02-06-2014, 11:37 PM   #14 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
had one of those, 82 model but 4 speed.
added an Audiovox cruise control and it made a world of difference.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 02-07-2014, 01:11 PM   #15 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
MK1 and MK2 have basically interchangeable front emd parts I think... There's an MK2 'big bumper' that works better as an air dam than the stock stamped unit. I ran my 1.6 with no rad fan and a grille block in all temps, never had a problem with it, just don't let it idle for more than maybe 20 min (if you do that sort of thing). The stock exhaust makes the engine fairly anemic, its max torque and overall curve is something like the gasser, but with less AUC (area under curve). Probably the single best thing you could do for MPG and a slight boost in power is add a non-vnt turbo and manifold from an ALH TDi, 2.5" turbo back open exhaust, and actuate the wastegate at no more than 4psi. Adjust your IP till you get a little gray smoke under load, then back it off slightly, and concentrate on staying between 1800-2400 rpm.
The idea is that while diesel engines don't 'produce vacuum', they still draw in the air charge under vacuum and this requires energy that would otherwise go into the piston and rotating assembly. The turbo will use exhaust heat to keep the piston faces from seeing as much vacuum, thus increasing efficiency. Technically no need to adjust your fueling calibration with the turbo, but if you're gonna add one, might as welll get the power boost from it, too.
Old 02-07-2014, 01:15 PM   #16 (permalink)
And don't worry about the CAI thing. Its not helping or hurting. If you add the turbo, don't bother with an intercooler and piping, at 4 psi and such low power levels you don't need it. If you have access to free washer fluid, consider water/meth injection kit. Also, the poster that mentioned PCV meant to say CCV, and that tube that vents from the valve cover to the intake manifold... put a catch can in it, or at least use a bore brush for a .45 cal. Its basically the 'flame arrestor' that Mercedes used in their CCV system, catches the oil that will eventually soak your filter amd cause a runaway condition.
Old 02-07-2014, 02:18 PM   #17 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
+1 on the camera lens, holy moley.
Nice find, man. If you never go fast, those old Rabbits will just go and go. Popular Science published a 75mpg rating at 35mph. Just puttering along.
The aero on those old Rabbits is just dreadful. I reckon virtually anything you do towards aero will reap huge rewards, especially in light of the engine's very modest output. You'll be pulling the power demands way, way down further into its sweet spot.
You might want to look into whether that engine has the upgraded head bolts. I understand that's a thing with the 1st gen VW diesel, head bolts loosening up and a resultant gasket blowout. [edit] Whoops, Cobb got there before me. Well, +1 on that too.
Old 02-07-2014, 05:17 PM   #18 (permalink)
Rabbit aerodynamics
Here is something to think about if you ever consider aft-body streamlining.
Just modifying the rear hatch area to more of a 'Kamm' roofline would give you about a 7.5% mpg increase on the highway.
Cobb (02-07-2014), renault_megane_dci (02-13-2014)
Old 02-07-2014, 05:39 PM   #19 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Look up "Top Gear sipster"
Project Sipster | Videos | Top Gear | BBC America
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following User Says Thank You to Superfuelgero For This Useful Post:
aerohead (02-08-2014)
Old 02-07-2014, 05:39 PM   #20 (permalink)
I had a 79 dasher diesel 1.3l 4 speed, dad had a 81 4 speed with od and upgraded to gti parts. He also had an 81 2 door without over drive, but ac.
