Old 03-22-2010, 10:44 PM   #21 (permalink)
Mirage - '93 Mitsubishi Mirage ES
90 day: 41.92 mpg (US)
Oh, I almost forgot:
I also removed a wiper. It was kind of broken, so I stripped off the whole mechanism and simplified it to only run the left side wiper. I looked at some more sleeker looking wipers, but they were too expensive for my (cheap) taste.
Old 03-23-2010, 06:14 PM   #22 (permalink)
Update:
I finished the last tank of me driving like a maniac (70 MPH, no regard for economy at all). $20 of fuel would net me at current prices around 7.3 gallons. That would last for only 200 or so miles.
Today, at 200 miles, with the gas gauge on empty, I was able to squeeze 42 more miles with P&G!
That improved my MPG from 28 to 33! A 5MPG increase from just trying out P&G.
To say that I'm excited is to understate it. This is really fun. I could have gone for the last drop of fuel, but I did not want to get stranded (if I had some spare fuel in the trunk I would have tried it, next time maybe).
This after doing P&G, filling the tires to 44PSI, and removing the mirrors. The car still has a bunch of heavy stuff inside, and the aero has not been really changed.
I'll P&G this whole tank, and then proceed to do the aero mods.
Old 03-23-2010, 06:45 PM   #23 (permalink)
Originally Posted by nayeliesuncle View Post
Update:
Reducing the weight of the car would help with MPG too.
For example you can remove junk from the trunk, extra passenger seats and head rests.
Old 03-23-2010, 06:49 PM   #24 (permalink)
I plan on:
Removing all the crap from inside the car. it's full of trash from the last owner.
Removing a tool box I carry just in case. I will downgrade to a smaller toolbox. The current one weighs like a ton.
Replace the full size spare tire with a space saver. Also get a scissors jack.
Remove the passenger seat.
I also plan to remove the A/C.
It's a pretty stripped down car. No power anything.
Old 03-23-2010, 06:57 PM   #25 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Honda was good about using 10mm hex for everything, so I have a very small set of hand tools that live in the car: three sockets, two extensions, one ratchet, two screwdrivers, vise grips, duct tape, and zip ties. That's all. The hand tools probably weigh 3lbs, and I can remove just about any part with them.
I hear it's warm in Puerto Rico. If it was my car, I'd keep the A/C, but perhaps you're better acclimatized than I am.
Old 03-23-2010, 06:59 PM   #26 (permalink)
I plan on:
Removing the rear seats would help reduce weight as well.
Old 03-23-2010, 07:13 PM   #27 (permalink)
Yes, it would. But then I could not take my daughter with me. She still uses a booster seat, and likes riding around with daddy. =)
Old 03-23-2010, 07:18 PM   #28 (permalink)
You are right. I just need basic hand tools. I'm just very OCD about having tools in every one of my cars. I will use your list as a guide.
Warm does not even start to describe it. It is HOT. Today was a bit over 90, with a lot of wind. I will remove the A/C because it is broken and I don't want to spend any money fixing it.
I'm used to driving around with the windows down, though.
Old 03-30-2010, 12:35 AM   #29 (permalink)
A little update:
I taped the front of the car. Left just a small opening for the radiator to get some fresh air.
Have not tested yet, as I'm getting used to driving differently and what not, but I swear that I can coast a bit longer than before. Also, coasting speed seems to be higher by a couple of MPH.
Am I nuts?
PS- I think I'm on my way to getting to or really close to 50MPG! =)
Old 03-30-2010, 12:38 AM   #30 (permalink)
Another question:
How do we go on letting the air flowing through the engine compartment flow out?
When I go with a belly pan, I don't see how it would work. Do I open a vent in the hood? Sort of like an Lancer Evo?
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
NEW project in the works 1993 2 door tempo TempoRacer EcoModding Central 11 04-04-2012 09:30 PM
New feature: EcoModder Project Library (help expand it!) MetroMPG Forum News & Feedback 8 10-01-2009 12:04 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
