UG error while calibrating...
Hello,
I've had the UG on for a few days now, seems like an awesome tool. I love it.
I went to calibrate the distance after reading it's beneficial, and especially knowing that what the speedo indicates is a little quicker than actual. My GPS states 55mph when speedo says 57mph. I'm leaning towards trusting the GPS there. Car has stock tires with fewer than 10k miles.
I parked, reset the trip B odometer just to compare, I went to the menu and reset all trip gauges then started my 1 mile drive. Used the GPS to measure distance.
Where I ran into an issue is when I stopped at 1 mile and went to the calibrate menu, then calibrate distance but I got an error "No distance to calibrate" or something very similar. I then paged over to the distance traveled and it said .96. So it does seem to be functioning and was reset for the test.
Any ideas? Thanks!
