Old 02-17-2009, 04:29 PM   #11 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
GM could learn a thing or two for the Volt here... or if they'd look at the EV1 skeleton in the closet.
I agree, clever hiding of the boattailage - that thing has a tiny rear end.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 02-17-2009, 07:48 PM   #12 (permalink)
0.24
Only good can come from it.M-B is so influential,even as it loses market share to competition.Should the Cd become a bragging right in marketing the car,then it can only encourage others in that market to realize it's a consideration in the consumer's mind.Everybody wins! Thanks Darin.
Old 02-17-2009, 08:51 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Neil -
Hi,
That upper grill must be (mostly?) blocked off, and the only other thing that jumps out at me is the lack of a 'B' pillar. And, they probably did an excellent job on the underside of the car, too.
I did some googling and found this picture of the grill :
New Mercedes-Benz E-Class Coupe Revealed Before Geneva Debut - worldcarfans (actually this is the same URL as the OP)
The upper grill appears to be open in this picture. The lower side grill/vents, and part of the bottom grill are blocked off.
CarloSW2
American Solar Energy Society
Old 02-17-2009, 09:00 PM   #14 (permalink)
- - '10 Toyota Prius III w/Navi
Hi All,
Reminds me of my 1974 Opel Manta, but with a shorter trunk.
And the shadenfreuda is really kicking in regarding the 2010 Prius Cd of .25 . Think Toyota could have done better. This proves it.
Old 02-17-2009, 09:18 PM   #15 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
WOW!
Now I (Finally) want a Diesel Benz
2012 Tesla Model S P85
2013 Nissan LEAF SV totaled by now deceased intoxacated driver.
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 02-17-2009, 10:23 PM   #16 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Some tricks involved that none of us are seeing? The bionic fish was a total box but had a low CD (something like 0.16?)
I can't help but wonder if some of the tricks used on it are used on this model. Prototypes are just test beds for ideas.
Old 02-17-2009, 11:00 PM   #17 (permalink)
The Bionic "Boxfish: has a drag coefficient of 0.19; which is pretty darn good.
Old 02-18-2009, 05:20 AM   #18 (permalink)
0.24 IS pretty good for a production car but it is easier to accomplish with a two door than a four door like the Prius.
That said I would like to see one in the metal and have a close look at how it all comes together.
Pete.
Old 02-18-2009, 07:19 AM   #19 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
The most aerodynamic variant of these coupés achieves a new world best in terms of drag coefficient: with a Cd-figure of just 0.24, this model is the world's most aerodynamically efficient series-production car.
this is quite important that
it reminds me of the opel calibra wich had a 0.26 Cd... but only for 8 valve versions with a partly blocked grill and different tires.... the 16calve versuibs differed in some aspects and had a 0.29Cd! something that's not often mentioned.
that doesn't mean this isn't quite an achievement, but i notice the front bumper on the white car and that on the gey car show lower is quite different, especially the shape of the grill and the wheel dams... so one must be a little carefull with reverse engineering
Old 02-18-2009, 10:49 AM   #20 (permalink)
found a few interesting shots on the interwebz....
a few spie shots from the car apparently on top of a truck, wich reveils some bits of the front and rear undertray.... nothing terribly shocking appart from evidence that it's definately there...
rear diffuser
and a bit of the front
i've slightly lightened some pics to reveal more detail
edit:
notice the "ridge" on the taped over taillights.... small spoilers to deflect the air somewhere? makes sence, if you wand taillights that curve around the car to produce that optically wider tail, but you want a clean edge to sepparate the flow
also my dad mentioned last week (as he returened from a course about the new insignia he has to work on as a mechanic) special attention had been given to the shape of various components from the suspention (i assume the ones that arent covered by panels) so these wouldn't disrupt the airflow
the flat spot on the rear suspention arm visible on the merc might be another one of these hard to notice details that help it get low drag
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
