Old 11-01-2010, 12:51 PM   #11 (permalink)
Cinco The Miata - '90 Mazda Miata
Team Mazda
Sports Cars
90 day: 36.13 mpg (US)
Oscar Wilde - '02 Honda Metropolitan
Motorcycle
90 day: 94.9 mpg (US)
I removed my antenna today.
Old 11-10-2010, 12:10 PM   #12 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
looks great
ive always liked miatas and have always wanted to get another one
wish the automatics got 30+mpg
i look forward to that underbody tray
Past Present Future?
Old 11-10-2010, 01:35 PM   #13 (permalink)
Team Mazda
Sports Cars
Motorcycle
gross
Old 11-10-2010, 06:58 PM   #14 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
you should remove the crankshaft pulley bolt, make sure it is in good condition, and then loctite it back in. The early short nose cranks had failure problems arising from the bolt coming loose, aided by overzealous tensioning of the belts. Make sure the belts are loose when you do this maintenance item.
Old 11-12-2010, 09:05 PM   #15 (permalink)
I thought that the risk was during the timing belt service. If the key wasn't put back exactly right, or things didn't seat correctly when torquing the crank bolt, the crankshaft nose would be either damaged immediately or later as the key shaft rounded out. If you didn't touch the bolt, the damage wouldn't happen.
This was fixed with the "long nose" crank in the 1.8L engine.
Old 11-12-2010, 09:13 PM   #16 (permalink)
There really isnt a great deal of support for the front balancer. When I worked at a race shop, it was a common failure for ones that werent taken care of.
Old 11-13-2010, 12:16 AM   #17 (permalink)
dday's Avatar
Hey nice car. I have a 91 stock and I too get about 32.x no matter how hard I drive it. Best tank ever was 37.x in the summer driving around 50 - 60 mph around a lake taking in all the sights. Have not done any mods to it yet but love the car the way it is. Just put the hard top on for the winter. Don't drive it much in the winter because of the snow but do take it out on the nice days here and there.
Old 11-13-2010, 12:30 AM   #18 (permalink)
I have a Z3, but I can really appreciate the clever design of the MIata. The "Power Plant Frame" is a strong but very light (either 8 or 12 lbs) aluminum ladder brace that connects the transmission to the differential. It eliminates putting the torque loads through the body, and transfers most of the thrust lift the whole way forward to the engine mounts.
It also enables a simpler one-piece drive shaft that puts the sliding splines at the transmission connection.
Old 11-13-2010, 10:36 AM   #19 (permalink)
Grasshopper
Originally Posted by AntiochOG View Post
gross
eh?
Old 11-13-2010, 12:43 PM   #20 (permalink)
Team Mazda
Sports Cars
Motorcycle
eh?
An automatic in a Miata just ruins the car in my opinion.
Miata modding bobsiopener Aerodynamics 22 10-02-2013 06:32 AM
Miata mpg bikin' Ed Success Stories 7 08-17-2010 09:04 AM
Hey guys, newb here, need advice Guns Trucks & Beer EcoModding Central 4 12-13-2009 04:36 PM
New here... doing a bit of hypermiling in my Miata. awarenessideas Introductions 1 01-08-2009 05:42 PM
LA Auto Show: Mazda Miata SVOboy EcoModding Central 4 11-21-2008 04:02 PM
