Old 03-15-2020, 11:44 AM   #11 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The three-dimensional Cartesian Coordinate system is a misapprehension of a fundamentally tetrahedral reality. It's all downhill from there.
I disagree. Because of the unique constraints on our movement in t, a vector (x,y,z,t) fails the additive inverse property of vector spaces and any set W = {x(t) ,y(t), z(t), t} is not a subspace, where a set U = {x(t), y(t), z(t)} is. So, while it may be true that reality is fundamentally a four-dimensional space, it is not very useful to us to represent it that way--and we've accomplished everything we have in the fields of engineering and science by doing just that.
Old 03-15-2020, 01:09 PM   #12 (permalink)
What's t got to do with it? Four axis at 60° demarcates physical space as well as three at 90°.
It starts with closest packed spheres and progresses to Vornoi cells.
Back in my day there was so much toilet paper and eggs that we would throw them at the houses of our enemies
Old 03-22-2020, 07:08 PM   #13 (permalink)
90 day: 40.81 mpg (US)
Work Vehicle - '17 Toyota RAV4
90 day: 31.89 mpg (US)
I haven't ever owned an auto, but I drive one at work. It's a Ford from around the same era and with similar displacement. Dunno if this is applicable or not, but I found that when I accelerate using cruise control (e.g. get up to 20 and then re-enable cruise) it immediately locks the torque converter and accelerates at around 80% load, shifting at pretty optimal points. I can't get it to lock the torque converter at that load without cruise control.
My experience has been that in city driving, even if accelerating more slowly isn't as efficient a way of accelerating, it results in lower average speed and less momentum lost at every stop, which tends to work out best.
Definitely get some FE instrumentation. Otherwise you're shooting in the dark.
I have a similar engine (Honda K series 2.4L) in my Insight. I haven't yet figured out how best to drive it, but I have observed two things:
1) It's a pig when it's still warming up.
2) Engine-off coasting helps a ton. Not that I'd recommend it in an auto.
