Old 01-20-2014, 10:43 AM   #11 (permalink)
Article on Patent
The patent is being promoting in a Toledo Free Press article.
Local inventor gets patent for internal combustion engine | Toledo Newspaper
Old 01-20-2014, 10:56 AM   #12 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Doug the scam artist keeps on scamming.
Pressure Gradient Force
The Positive Side of the Number Line
Old 01-20-2014, 09:58 PM   #13 (permalink)
He's either an attention ho addicted to notoriety,
or scamming really does pay well.
Old 01-21-2014, 10:37 PM   #14 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Would like to see some hard data on economy by a University or independent testing lab.
Old 01-26-2014, 05:57 PM   #15 (permalink)
WSPD Toledo Radio Interview
WSPD did an interview with Douglas Pelmear. There was not much skepticism from the host and no mention of the defaulted loan to Henry County.
1/22 Doug Pelmear Has Invented An Engine That Gets 110 MPG
Old 01-26-2014, 08:01 PM   #16 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
He has the electrics inside the engine
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 01-26-2014, 08:10 PM   #17 (permalink)
Originally Posted by JRMichler View Post
Somebody believes that his electromagnet patent has value. The US Patent Office just announced that his patent has been granted, the issue fee has been paid, and the patent will be published December 31, 2013. Patent Number 8,616,175.
If you want to install permanent magnets on engine internal moving parts AND electromagnets in the block or wrapped around a spark plug AND a control system to make the electromagnets pull or push on the permanent magnets, then you need to pay royalties to Doug Pelmear. After you negotiate terms.
I read about a Russian engine at least five years ago which from the description did the same thing.
International Patent and US Patent are different birds, from the sounds of it he cannot even afford the maintenance fee on the Patents. That would be another problem.
Old 01-27-2014, 11:32 AM   #18 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thumbs down
What a joke!
HP2g Skip Fire™ Cylinder Exclusive Variable Displacement
What it is - The HP2g Skip Fire™ is an engine management system capable of operating an engine on any number of cylinders upon demand and from the maximum number down to one. Rotating the firing cylinder to saves wear. The Skip Fire can change the fuel economy in targeted vehicles, thereby reducing fuel costs by 33%. In test Semi (over the road loaded) it averaged 10.44mpg with Skip Fire and 6.39mpg without.
How it works – The HP2g Skip Fire™ - Variable Displacement shuts off fuel to cylinders and rotates the cylinders of fire. This can go down to as low as 1 cylinder (after normal engine operation temperature). The engine is still opening and closing the valves bringing in cool outside air which is introduced to a HOT CYLINDER. This allows the air to expand pushing the piston = STIRLING ENGINE effect (from 1816)
Competitive Advantages – The HP2g Skip Fire™ system is far advanced from the variable displacement systems currently manufactured by the world’s OEMs, (which only operate to shut down half of an engine’s cylinders always in the same firing position (in the automotive market only)). The current systems also fall short of the fuel savings and emissions reductions offered with the Skip Fire. The Skip Fire has the ability to be updated and serviced at a shop or at home via a laptop computer through the internet. The Skip Fire application is unparalleled in the automotive & transportation world.
Source: Energy Technology Company w/ 110mpg Hybrid V8 Engine.
