11-20-2014, 08:52 PM
EcoModding Newbie Girl
Redline Power Chip: GOOD? BAD? UGLY?
Anyone looked into this?
Redline Power Chip myth debunked - FROM THE SOURCE! | eBay
Would love to hear from ya'll about your experience with this.
The Following User Says Thank You to leety For This Useful Post:
11-20-2014, 10:01 PM
If you know how to tune an engine, you can get better mileage out of it but usually not much. Slapping some ebay power adder chip will probably get you lower mileage.
The Following User Says Thank You to Daox For This Useful Post:
11-21-2014, 10:12 AM
Redline Powerchip: No longer a registered user. Uh... guess that's all there is to say about that.
If you want something that works, get something programmable and proven, like a Unichip Q, or a flash-tuner like Cobb. Well worth the extra money. But for economy... they take a very long time to pay for themselves.
The Following User Says Thank You to niky For This Useful Post:
11-21-2014, 10:59 AM
Depends what car, how much you drive, and what EMS. If the car is less fuel efficient and there are easy tweaks to save gas it could pay for itself quickly. For example, Porsche's M96 engines had a very dumb VVT setup that was always advanced, simply switching that off would get you a bit more mpg.
Another thing you can do is use a 200 dollar narrowband simulator with wideband O2 to make your engine run lean, but you would not be able to run as lean as with a standalone and so it would save you less fuel. However standalones are like 1k minimum.
The Following User Says Thank You to serialk11r For This Useful Post:
11-21-2014, 11:23 AM
Rat Racer
Best bet for tuning is find a good model or make specific forum and find out what they use for tuning.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
11-21-2014, 12:45 PM
Eco-ventor
The Following User Says Thank You to jakobnev For This Useful Post:
11-21-2014, 11:53 PM
Using programmers for gasoline engines for the reason of improving fuel economy usually doesn't work.
11-22-2014, 01:51 AM
Thanks Ya'll I figured the silver bullet was little more than BS but I figured you guys would share some info with me on this post, and you did ;-) Thanks much.
11-22-2014, 01:53 AM
#9 (permalink)
I'm working with a 1992 Honda Civic VX, working on deferred maintenance issues first. I'm get all the systems in a serviceable state. While I work on those matters, I'm researching some of the fun things I can do next ;-)
11-22-2014, 08:17 PM
#10 (permalink)
Intermediate EcoDriver
Originally Posted by leety
I lost count of the spelling and grammar errors on that page. Don't waste your money.
That said, I purchased a HyperTech Max Energy Power Programmer for my Mustang in May of 2009. This is far more than a resistor in parallel with the Intake Air Temperature Sensor. It plugs into the OBD-II port and re-programs the ECU to make minor adjustments to air/fuel ratio and ignition timing for more power and torque. It makes a noticeable "seat of the pants" (and dynamometer graph) difference in low-end torque. It doesn't make a noticeable difference in fuel economy unless I program it for premium fuel, which yields lower MPG, primarily because premium fuel has less energy per gallon than 87 octane regular fuel. It cost $360. It won't pay for itself in fuel saving, since it doesn't make a difference in MPG, but the additional low-end torque is worth the price, from my point of view.
YMMV.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
The Following User Says Thank You to Mustang Dave For This Useful Post:
