Old 12-29-2011, 05:42 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Nikola Todorov Kolev diesel engines claim 90% mechanical efficiency +30% FE levels
HI,
I was contacted by this guy and he has some very nice looking engine consept going on. There is already working prototypes and priciples are patented. Trying get OEMs to produce it.
Spead the message around,
Vesa Tiainen
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 12-29-2011, 06:27 AM   #2 (permalink)
Cool layout. Don't see how it gets a diesel cycle from 50 to 90% though.
Old 12-29-2011, 07:39 AM   #3 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
In the info on youtube is says 90% mechanical. Quite different from 90% total.
It also says 140g/hp. (But i assume they mean hpH) That's 190g/kwh or 44% for diesel.
The Following User Says Thank You to jakobnev For This Useful Post:
Vekke (12-29-2011)
Old 12-29-2011, 08:12 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Thanks for that correction I modified the topic... they claim 30% better FE and 90 % mechanical efficiency.
They are using basic other mechanical and injection components at the moment. More videos should come in the near future.
Old 12-29-2011, 10:55 AM   #5 (permalink)
Diabla - '09 Renault Laguna Hatchback
Hi
I`m stupid when it comes to mechanicals, so can someone explain this a little better?
As far as I think I understand this engine does not use piston rods but uses more of a direct drive and thus has lower losses through friction and mechanical force transfer and because of the compact opposite side layout also needs less metal and hence less weight for the same amount of pwoer as would a traditional engine layout.
Sure looks interesting, yet I wonder how much stress the direct drive does on metals and how much vibration this design produces if compared with the traditional one.
Old 12-29-2011, 12:07 PM   #6 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
90% mechanical & 44% brake thermal efficiency are already within the range of modern diesels (at least at peak efficiency operating points). Interesting concept non the less. The potential mechanical efficiency advantage I see would be lower side forces on the piston.
I think the motion of the piston is still the basic slider-crank motion, so as far as the in-cylinder combustion, I think everything should be identical. Therefore closed cycle efficiency (and I assume pumping efficiency) should be the same as a conventional engine. So, the only advantage this engine would have efficiency-wise would be the mechanical efficiency. Even if the friction goes to zero, you're not going to get a 30% brake thermal efficiency advantage.
Interesting, but I guess I don't see a 30% efficiency improvement. The long-term durability of that "wristpin" joint concerns me too.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
engine, fuel efficiency, high, kolev, todorov
