View Poll Results: Scan Gauge II or UltraGauge?
Scan Gauge II 18 22.22%
UltraGauge 63 77.78%
Voters: 81. You may not vote on this poll
Old 05-23-2011, 09:54 AM   #1 (permalink)
The Fit is MPGo!
Dunkler's Avatar
Blue - '07 Honda Fit Sport
90 day: 42.71 mpg (US)
Hot Rod - '84 GMC C1500
I am looking to buy one of these today for my Fit. I need advice and opinions for those that own/have owned either of these and which is more accurate or the better buy.
Thanks guys!
Old 05-23-2011, 10:10 AM   #2 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I've only ever used the Scangauge. It has programmability features, but for a standard (non-hybrid) car that feature doesn't add much. I hear the Ultragauge is decent too and has the ability to show 6 gauges instead of 4.
My answer is yes. Get one or the other. I don't think it matters so much which one. Having the numbers in front of you matters very much.
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
ciderbarrel (04-22-2012), Dunkler (05-23-2011)
Old 05-23-2011, 11:45 AM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I own both. The UG wins hands down for value, ergonomics, ease of visibility, and everything else, for the vast majority of users. The only people who can get an advantage with the SG are those who want a specific function that's not supported by the UG, like transmission fluid temperature or HV hybrid battery pack voltage, and only if the SG can be programmed to display it, and the user is willing to program it into an xgauge. There is no accuracy difference between the two.
The UG is a far better value for the average user. You can display 18 gauges with the UG with two button pushes (or none, if you want to let them cycle automatically). It can take you 20 button pushes to display 5 gauges with the SG, and well over 100 button pushes to display 8 gauges with the SG.
The UG will recognize all the available gauges for your Fit and be operating in less than a minute. The SG will require hours of tedious programming to be fully functional using its maximum capability.
The UG display is much more modern. The SG costs $140-$160. The UG costs $60. I would buy the UG for myself and recommend it for most users. I only keep my SG because I expect to buy a Prius some day. Otherwise, I'd sell it, buy an UG, and keep the change.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following 5 Users Say Thank You to SentraSE-R For This Useful Post:
ciderbarrel (04-22-2012), Dunkler (05-23-2011), mikeyjd (03-01-2014), wadesworld20 (01-13-2020), weerrolf (11-10-2011)
Old 05-23-2011, 11:51 AM   #4 (permalink)
The Fit is MPGo!
Dunkler's Avatar
awesome info guys! Based on Sentra's comparison, UG is definitely a better buy!
Old 05-23-2011, 12:16 PM   #5 (permalink)
Hypermiler
Wagons
"hours of tedious programming" ???
When I swap my scangauge between cars, I do this.
home-more-fillup-done
home-setup-engine-set size
maybe click a few times to change some of the 4 gauges showing
drive
The UG obviously wins on price and display, though.
Old 05-23-2011, 12:25 PM   #6 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Ford Mustang GT
90 day: 24.7 mpg (US)
I read somewhere that the SG can show dollars per mile by entering how much the fuel cost was. Im in the pre-buying boat. I havent decided on which one to get. The UG is looking pretty good. Mostly because of the lower cost and modern look. It actually looks like it should cost more.
Old 05-23-2011, 12:32 PM   #7 (permalink)
I own a SG2, which has a detachable cable that makes it possible to swap between cars -- though I don't think that this is easy to do. Each vehicle has to have it fuel capacity calibrated, and the speed has to calibrated as well, in order to get a reasonably accurate FE number.
But, I think you can buy 2 Ultragauges for a bit less than 1 SG2? And, two of the numbers on the display are larger size, which makes them very easy to compare the instant and the average FE. A friend bought the UG, and I think I would own it if it was available a few years ago.
Old 05-23-2011, 12:40 PM   #8 (permalink)
Hypermiler
Wagons
I swapped it yesterday into the Odyssey for the day.
Unplug
plug
set engine size
speed calibration is the same on both, but in any case it's only a couple clicks
quick fillup procedure
set fuel calibration if needed. I don't.
drive
Then I did the same this morning back into my Civic. The hardest / longest part of the process is stringing the cable so you don't trip on it. Once you know the calibration it's quick and easy. I use 1.8 engine size vs my actual 1.6 to get my 12.5% offset. It takes fewer clicks that way. The Ody is dead on at its actual 3.5 engine.
Fuel capacity is irrelevant. It only affects the Miles to Empty gauge. I have a fuel gauge in the dash so I just ignore that.
Old 05-23-2011, 12:52 PM   #9 (permalink)
Pishtaco
SentraSE-R's Avatar
You took my remarks out of context, Andrew.
Darrell
Old 05-23-2011, 01:00 PM   #10 (permalink)
Hypermiler
Wagons
He drives a Fit. It doesn't need the special programming for that vehicle. For this application that's a non-issue.
I'm not saying the SG is better than the UG. Just give it a black eye it doesn't deserve.
