Old 10-01-2009, 12:37 PM   #1 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Exclamation No energy savings with 35watt HID's !!!!
So I heard a rumor that all aftermarket 35 watt hid's simply have a resistor to output 35 watts- this means the system is still using 50 watts because of the resistor.
In other words, your better off going with 55 watt hid's because you get all the wattage in light output instead of light+heat in the 35 watt hid's.
Thoughts? True or not? Anyone that can test this in their car if You have aftermarket hid's?
Old 10-01-2009, 12:53 PM   #2 (permalink)
LOL no
Not true.
Old 10-01-2009, 01:52 PM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Normally, when someone asks a question such as this, and you answer it, you'd do so with a reference...
Old 10-01-2009, 02:43 PM   #4 (permalink)
Well the reasoning behind it is to fool the cars ecu into telling it that there is still a bulb there (since it's using less watts some cars might throw a code).
Again, just rumors I've never actually tested a ballast before with a multimeter.
Old 10-01-2009, 03:01 PM   #5 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Well, you need a question mark instead of four exclamations in the title, but I couldn't imagine a 3A headlamp in place of a 5.5A one would create any problems bigger than a "bulb out" warning light. Maybe some HID makers install a resistor to draw extra current, but I doubt it. Write to the manufacturer you're thinking of buying from, then post their response here. I do know the fancy headlamps on the Prius draw less than 55W, which proves that such lamps are out there.
Old 10-01-2009, 03:21 PM   #6 (permalink)
darcane's Avatar
*blink* *blink*
Headlights are basically just a simple DC circuit... Think V = I x R and P = V x I
The 35W lights should have higher resistance which means lower amps. Power is thus reduced because the amps are lower, the voltage has stayed the same (nominally 12V).
However, in the grand scheme of things, it's almost irrelevant. Saving 20 watts x two lights is 40 watts. 745watts per hp, so you're saving a whopping .05hp by switching lights. I'd rather have the better lighting.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 10-01-2009, 04:14 PM   #7 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Why would anyone need a bulb out idiot light. Looking out the windsheild and half the road is dark is a pretty good indicator.
Old 10-01-2009, 04:18 PM   #8 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
People are becoming dumber and dumber every year, that's why.
Old 10-01-2009, 04:22 PM   #9 (permalink)
Schwartzejetta - '00 Volkswagen Jetta TDI GL
90 day: 52.87 mpg (US)
It's not so much an idiot light, but that the ECU will note a fault code if a circuit's not measuring up as expected.
It's an engineer's mind on thoroughness, when they already include an ECU code for high/low/no voltage on engine sensors, to extend the same to other circuits on the car.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 10-01-2009, 05:03 PM   #10 (permalink)
Thats why you get one of these.
Error Code Eliminator - 3 (PAIR): DDM Tuning - HID Kits, HID Bulbs, DEPO Lighting, BMW and Porsche Performance Accessories
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
New 1/2 house A/C time dremd Saving@Home 16 06-17-2010 10:11 PM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
