Old 11-30-2009, 12:12 AM   #11 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I've had AWD, 4WD, and FWD/RWD. I prefer the 2WD. It gets me to remember my limits. If i can't get out of the driveway, I don't go out on the road. It's that simple.
I don't believe that AWD handles any better with a responsible driver behind the wheel, except in the case that the responsible driver makes a mistake. It's bound to happen, of course, but does it merit having AWD sucking up your fuel and maintenance budget all the time? No. I don't think it does.
Most of the time, Simple is Effective. Anything more is often benign, therefore a waste.
Old 11-30-2009, 12:31 AM   #12 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Originally Posted by wdb View Post
How about a light AWD?
No such animal, AFAIK. Name me one that weighs <3500 lbs that's available in the U.S.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 11-30-2009, 01:23 AM   #13 (permalink)
1988-1991 Honda Civic Wagon RT-AWD, for one. I'm not sure about the Mitsubishi GSX and variants, they might be in that weight range, as well.
Either way, it's not necessary.
Old 11-30-2009, 03:20 AM   #14 (permalink)
Pishtaco
SentraSE-R's Avatar
I wasn't aware of that Civic model, but it is at least 19 years old now.
Mitsubishi Galant VR-4 and Eclipse GSX, Eagle Talon TSi AWD, etc. are in the 3300 lb. range, essentially 3500 lb cars.
I'd put my money on a heads-up driver in a 2WD over an average driver in an AWD.
Darrell
The Following User Says Thank You to SentraSE-R For This Useful Post:
Christ (11-30-2009)
Old 11-30-2009, 11:19 AM   #15 (permalink)
That's exactly how I feel... replace the added weight and complexity of the AWD system with a trained high speed course and associated driver education. Stop making the cars safer, make the drivers more responsible.
Old 11-30-2009, 12:42 PM   #16 (permalink)
I have to disagree a bit. 4WD/AWD can be useful if you live where there are mountains, and a good light 4WD, like for instance pre-'85 Subarus, can get decent MPG.
That said, I did spend a couple of years making weekly trips over the Sierra Nevada (via Calif 88) in my Insight, and the only time I couldn't get through was when a jackknifed semi had blocked the road.
Old 11-30-2009, 01:22 PM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
the majority of the population is not rural however, cuz that's just not what rural means.
Old 11-30-2009, 01:45 PM   #18 (permalink)
I'm rural. I've never needed 4wd. If I can't get out of it with two wheels, I can get out of it with two feet, and that's probably how I should have gotten into it in the first place.
Hell, I go mudding with 2WD trucks.
Now, if you wanted to get up to where I get wood for the stove, that would require 4WD. And even that doesn't always make it.
Old 11-30-2009, 10:52 PM   #19 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Darn near every Subaru, old and new, for starters. TT and 3- and 4-series Audis, probably the older ones because they've been bloating upwards of late. (So have Subies, sad to say.) Honda CRVs and their ilk, although I am loathe to call their systems "AWD". A bunch of itty bitty SUV's from across the Pacific, from Kia and its bretheren.
If you insist on old and quirky there is of course the Justy.
Old 11-30-2009, 11:02 PM   #20 (permalink)
I had Tempo AWD up there but took it down since it's 4WD.
