Old 08-24-2009, 08:52 PM   #21 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Don't parachutes have vents in them to keep air going through it, so that it stays billowed instead of collapsing as air rushes around the sides of it?
I think that's the reason that parachutes are so... parachute-y... if you sealed a parachute, I presume it wouldn't even work effectively past the opening point.
Old 08-24-2009, 09:04 PM   #22 (permalink)
Key Concepts
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Christ (08-24-2009), lunarhighway (08-28-2009)
Old 08-25-2009, 12:40 AM   #23 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
Yeah. I want my parachute sealed in this case. Or, perhaps, not a parachute.
Made a few tweaks to the panel today, I think it's on the right track now.
Lowered the rear edge to better meet the spare tire well curvature, and added some precision coroplast:
Started on a set of small aluminum panels that will help seal off the front and side edges completely.
Also tweaked it around to bring it a bit higher off the ground. I'm now able to convince myself that this thing should be helping, but I'll have to get some FE results to feel better about it. Today's commute was inconclusive, but also not great.....
Old 08-26-2009, 03:18 PM   #24 (permalink)
I think the tweaks were good. Took a long(ish) road trip down to Cedar Point yesterday. For those of you who aren't familiar, it's a place designed specifically to do one thing: use energy.
I think the energy requirements to fire the "top thrill dragster" just once probably exceed the amount of fuel I'll ever save through eco-modding. A 5 ton train accelerated from 0-120 mph in 3.8sec.... But that's neither here nor there. (and btw it is a truly amazing experience)
Back on topic: Recorded my best ever scan gauge readings, without any special attention to driving. The roads in Ohio are great, aside from the 5" rock left right in the middle of my lane! doh. Ripped off one piece of coroplast and left a nasty scrape in my skid plate. Thank goodness its there though, or I would have lost an oil pan instead. I can just picture the inbred farmer trying to save fuel by leaving his tail gate down as he transports his load of rocks.
I think this thing is really helping though. sweet.
Old 08-26-2009, 03:58 PM   #25 (permalink)
LOL - There's a door at the hospital that my son was born at that just rotates all day... even if noone is in it/walking through it.
I call it "The several thousand dollar renovated massive rotating waste of energy."
Just inside that door, they put a traditional automatic sliding door... apparently, they figured out that the giant rotating door referenced above made a huge hole for air exchange...
Old 08-28-2009, 04:47 AM   #26 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
Ever driven down a dirt road? I think I'd want something a little quieter than metal for driving around here.
Old 08-28-2009, 09:31 AM   #27 (permalink)
Not a peep out of this panel so far. Haven't driven down any dirt roads though; I avoid them whenever possible. Perhaps not feasible in Bozeman!
I still wouldn't really expect it to make a ton of noise; its centered under the car and away from the edges. My Michelin energy's tend to not throw any rocks also.
Old 08-28-2009, 09:38 AM   #28 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
Key Concepts
suppose it's diffult to make a rear undertray that's completely sealed at the front, so air might get above it... would there be any benefint in creating exit vents for the trapped air, this might energise the boundry layer and pervent turbulence either local on the tray, or in the overall drag of the car
Old 08-28-2009, 09:55 AM   #29 (permalink)
It might be hard to see in my pics, but I really doubt much airflow is getting on top of my panel from the front edge. Some may be sneaking around the sides, or being forced in from the wheel wells if strange aero is happening there. But the front and rear of the panel are pretty well concealed.
I thought about trying to make strategic exit points for any entrapped air pressure, but it just made more sense to have it all smooth.
My scan gauge is showing some noticeable gains for this piece; best ever commuting mileage result on the way home yesterday (and still at 75mph). woot.
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 09:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 10:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 07:18 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 09:14 AM
Belly Pan on the Saturn Raysp30 Aerodynamics 8 07-14-2008 02:46 PM
