05-25-2010, 01:52 AM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
How to remove tires from rims manually (no damage).
This is more for scrapping the metals than anything, because honestly, how many times are you really going to do this in your life... However, it's not a difficult job, and only takes 5 minutes to remove a tire, and about 5 minutes to put one back on, even if you don't have the stand I have. (I used to do this with a bumper jack and a couple small trailer leaf springs.)
So, on with it:
First, remove the valve core from the rim using either a pair of pliers, a knife, etc... Whatever will get it out of there:
Next, you need to break both beads away from the wheel rim's seats:
On my tire stand, there is a pneumatic press that does this. I used to use a bumper jack with the ground stand on the end to do the same job:
I stand on the ram to keep it aligned while I start airing it up, and because the stand isn't bolted to the floor yet. It moves alot.
Next thing, after front and rear beads are released:
Place tire on stand, and insert the lug holder (little pin in the lug hole).
Place the locking collar:
And add air to lock. This prevents the wheel from moving/spinning around on the stand while you remove the tire from the wheel rim.
Making sure you're working from the front of the wheel, insert the tool from opposite your position, under the tire's bead and inside the rim. Line the notch in the tool up with the rim's lip and pull the tool back toward yourself:
Determine which direction you'd like to work, then, push the bar away from the center post, and forcefully draw it back against the post. It is very important that you let the tool spin in your hand when it hits the center post. This allows the tool to "walk" the tire's bead over the rim's lip. After you've done the face, do the rear the same way, except it needs to come over the face of the wheel, too. When you're done, you have:
Here's a short video demonstrating tire removal using the tire bar tool:
05-25-2010, 01:55 AM
For anyone wondering why I do this:
A steel rim is normally worth about a dollar in scrap, sometimes more. I can remove a tire in about 5 minutes. That's about $12 an hour.
Aluminum rims are worth at least $11 each. Again, 5 minute removal time: 60/5=12, 12*$11 = $132/hr.
How many jobs does anyone know of that pay $132/hour for a little labor?
05-25-2010, 03:23 AM
Formula - '96 Firebird Formula/Trans-Am 90 day: 19.31 mpg (US)
If you can buy the tub of wheel bead grease, or just keep dish soap diluted in a squirt bottle, it makes life a lot easier getting the bead off.
Though, back in the day, I could have a tire off the rim, and new one mounted in that time, from the moment I pulled the valve stem out to the moment it was aired up to the proper PSI.
Some could do it in half that!
Though, where are you getting wheels/tires for cheaper than their scrap price?
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
05-25-2010, 03:26 AM
Too many cars
Your tire tool looks a little nicer than the one I got from Horrible Freight. My bead breaker is all mechanical leverage. I used to bolt mine down on the tailgate of a truck when I needed to use it, but I might switch to the deck of the trailer I recently picked up.
I prefer scrapping catalytic converters for $$$.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
05-25-2010, 06:59 AM
Or if you don't have the fancy tools...
"Be smarter than the tire!"
YouTube is awesome.
05-25-2010, 07:08 AM
Or, in half the time... minus the beer!!
05-25-2010, 08:32 AM
Alloy rims really need rim guards? If you have a garage wall (providing a fulcrum) and a long (6-8 foot) 2x4 and a short piece of 2x4, you can break the bead that way. I've done a number of motorcycle tires this way; and they are harder to do than car tires due to their much narrower section.
05-25-2010, 12:06 PM
Both from people locally, as well as from the local junkyard.
They sell w/t on aluminum for $16, and they sell them on steel for $11 each. In either case, the tires are $5.
Take the tires off, use/sell them, and scrap the rims if they're not decent enough to sell.
I also get them when I buy cars and trucks to scrap, as I strip them down. I also get them when I pick up scrap from locals, who are just tired of stuff "laying around".
05-25-2010, 12:08 PM
#9 (permalink)
If I really felt ambitious, I'd just put the motor back on the log splitter. That's the fastest way to remove a tire from a junk rim - just squish the rim. Tire falls off. Takes less than 10 seconds.
However, I don't mind actually working a bit.
When I'm really in a hurry, I can dismount, clean, re-mount, and air up a set of 4 tires in about 25-30 minutes. I've never done all 4 using that tool, the last time I did a set of 4 was in my driveway with the leaf springs and bumper jack.
05-25-2010, 05:23 PM
#10 (permalink)
home of the odd vehicles
I've found you can just drive the truck over a deflated tire on the rim to pop it off (although that does use gas)
