Old 04-29-2013, 11:36 PM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
OBDII Protocol
So according to my Ultragauge I have the 9141 OBDII protocol. According to the UG user manual, this protocol essentially sucks (they use different words! ) It got me to thinking if a protocol change is possible. I'm not worried about cost or the nitty gritty, just if it is possible and a basic idea of what would be involved.
Thanks!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 04-30-2013, 05:15 AM   #2 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
You would need to replace the whole ECU, if you first find compatible, and adjust everything again.
Why it sucks?
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 04-30-2013, 02:00 PM   #3 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
all OBD2 protocals suck, they have way too much overhead for rapid datalogging.
changing your protocal isn't something simple, since not only would you have to change the programming of anything in your vehicle that communicates with the PCM, you'll probably need to modify the internals of the PCM as well, neither of which are going to easy to do.
Old 05-27-2013, 02:26 AM   #4 (permalink)
MegaSquirt - Electronic Fuel Injection Computer by Bowling and Grippo ©2010
But not worth if all you want is to change the OBD protocol
Brrrmm
Old 05-27-2013, 03:21 AM   #5 (permalink)
Lots of Questions
Except that in California, that is probably going to be illegal, unless it is a track car.
Best EM Quotes:
Old 05-27-2013, 04:11 AM   #6 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Nothing wrong with the 9141 protocol.
It's fairly easy to understand...
Why would you need to change it? It's a very fit for purpose protocol...
