Old 05-29-2009, 07:17 AM   #21 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by cfg83 View Post
Eddles -
Rats. I wish there were a "tyrerack.co.uk" for you.
I googled around, and I think the terminology would be "high pressure valve stems" :
SELECTING PROPER VALVE HARDWARE - May 6, 2002
http://www.techtirerepairs.com/tech_...0Issue%202.pdf
But, the above might not work if the *size* of the higher PSI valve stem is not compatible. I just don't know.
Let's wait for CapriRacer to chime in, he has the expert knowledge.
CarloSW2
Here's the problem from my perspective:
1) If you are planing on using more than 60 psi in a passenger car tire - well, I'm already on record as recommending against this.
2) But if you are still determined to do it, then I feel obligated to give you advice to do this safely: Please use high pressure valves as indicated above. The problem will be at the retail store end.
They are going to look at you kind of cross eyed, because the valves they use are appropriate for all uses - except high pressures, which is when they'll use valves for light trucks ( meaning LT metric tires) - and they might not be the correct size.
So I would suggest you buy and mount your own valves.
First take the assembly in and have the tires dismounted. Using a knife or razorblade, cut off the old valve (if it is an all rubber valve, which you will find out very quickly!). Then replace the valve with this:
You should be able to find it at any car parts place that has tire stuff. It's designed for chrome wheels and will accommodate both size valve holes. It's a screw-in, so you shouldn't have any trouble installing it.
Then return to the tire shop to mount your new tires. They won't mess with the new valves, because they'll be chrome - and of course you will have told them not to!
For those with TPMS's - and I recommend retaining the device as a good safety feature - this gets a bit more complicated - beyond my ability to know all the possibilities. Sorry.
Old 05-29-2009, 09:21 AM   #22 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
Not going to inflate my tires to 60 PSI - that's way beyond my personal comfort zone!
I've finally decided to get 44 PSI rated tires and not inflate it beyond 49 PSI maximum - I'll probably inflate it to 47 PSI which is 7% over maximum.
Thanks for your advice anyway!
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Old 05-29-2009, 02:10 PM   #23 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
try it for yourself. Inflate all your tires as much as you dare, get to a set speed, brake as hard and fast as possible, and measure your distance. Then try again with the pressure listed on the vehicle information label. Your stopping distance will be much less.
Old 05-29-2009, 02:13 PM   #24 (permalink)
Basjoos Wannabe
Sure it would, if you overdid it. But most front wheel drive cars are nose heavy anyway, so a bit of oversteer added to the equation might help balance things out. But it could be taken too far and like you said, cause WAY too much oversteer.
Old 05-29-2009, 02:26 PM   #25 (permalink)
Basjoos Wannabe
Here's the link to the wikipedia link on tires
Tire - Wikipedia, the free encyclopedia
follow the references. It is generally well known that overinflation puts less ruber on the road, hence the lower rolling resistance. But rolling resistance goes both ways. If there is less resistance in rolling, there is less resistance between the tire and the asphalt, giving your brakes less of an ability to stop the vehicle.
Old 05-29-2009, 02:26 PM   #26 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I know the Goodyear Assurance "Fuel Max" tires are all rated to 51 psi. Since you're in the UK I would look at the "Efficient Grip". More than likely they are too.
Don
Old 05-29-2009, 02:28 PM   #27 (permalink)
Eddles's Avatar
Okay, let's look at my manual here. Feast your eyes on the unladen front tire pressures for the Y17DT engine on the leftmost column. It is all 35 PSI no matter what tire is used. The 61 PSI tire is just the "space saver" spare. Now look at Y17DT (ECO4). Now it says 41 PSI. Tell me why can't a Y17DT owner inflate his/her tire to 41 PSI? It's the exact same car. Also note the pressures for the ECO4 rear tires when fully loaded? It says 49 PSI. If it's really unsafe for me to run my tires at 49 PSI, why would a manufacturer of the 2nd most common car in the UK that weights only 2,500 lbs recommend this?
The Following User Says Thank You to Eddles For This Useful Post:
SVOboy (08-16-2009)
Old 05-29-2009, 02:29 PM   #28 (permalink)
Eddles's Avatar
Don
Thanks for this,
Unfortunately the Efficient Grip doesn't come in 175/80/14 - which is a fairly rare size, annoyingly enough.
Old 05-29-2009, 03:14 PM   #29 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I've been wanting to know the same thing. It just reinforces my thoughts on traction vs pressure and i'd like to hear a professional opinion on this.
Thanks for posting the picture of your manual Eddles.
ollie
Old 05-29-2009, 03:24 PM   #30 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
CapriRacer -
Thank you for posting that. My information was vague. I was able to get tires rated at 51 PSI, so that's my max. Because passenger tire valve stems are rated at 65 PSI (according to that PDF I cite in my previous post), I should be fine.
For additional safety, the next time I get a set of (51 PSI rated) tires, I will make sure they install the valves you cite. If they don't have them, I will get some myself.
CarloSW2
American Solar Energy Society
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
