Old 07-10-2011, 04:59 AM   #41 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
I'm going to continue using a pint of kerosene at each oil change run for 15 mins before the change. I've never tried the ATF as an oil flush. Have used a pint of water to clean carbon...but am worried about the 2 $50 O2 sensors in this car.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 08-21-2011, 11:49 AM   #42 (permalink)
Changed the MS additive laced oil after around 1200 miles...was just slightly dark....so not a lot of carbon etc....left to remove?
Old 01-26-2012, 07:30 AM   #43 (permalink)
i need help with my oil additive
Old 05-07-2012, 05:20 PM   #44 (permalink)
Very interesting testing! I also did some testing about 5 years ago with 2 different air cooled motors. I measured oil temp, engine RPM @ same throttle, head temp, and oz-in lbs to turn motors without heads. I was very hopeful that the data would show some good results. The data I collected showed no difference or at least nothing I could measure! I really was surprised because the science & technical day looked very promising.
