Old 10-14-2008, 04:21 PM   #21 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 Honda CiViC HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Originally Posted by RH77 View Post
It's just finding the stuff cheap. Costco would intermittently have it, but it's just demands the coinage.
I used to buy Mobil 1 @ Costco, but...
The 'problem' with buying oil at Costco is, you're V limited in your selection!
True, the limited amount of oil they do carry is usually of decent quality, but they don't, for instance, carry Mobil 1 10W-30 'High Mileage' - which is where most ppl want to be these days - especially anyone running a pre-2007 I4 motor [LINK]!
With an I4, it IS possible to have too many additives. What you *need* is a balanced additive package... and that would be Mobil 1 10W-30 High Mileage. These days, the 'garden variety' Mobil 1 has too little additives ('zinc' aka ZDDP [LINK] for example) for engine longevity!
Don't believe me?!?!?
Here you go: Compare the differences in 'zinc' between GF-4 and non-GF-4 oils.
AFAIK, the only Mobil 1 Costco sells is the regular ol' neutered Mobil 1 with the government mandated, GF-4 diminished additive package. To be fair, NOBODY sells EVERY kind of Mobil 1 motor oil - there are just too many different varieties!
I just changed my oil a couple of hours ago - Mobil1 10W-30 (High Mileage) with a Purolator PureONE filter. I bought the oil @ Wal-Mart ($26 - 5 qt/bulk) and the filter @ Pep Boys ($5.99 - PL14459).
That's about as 'cheap' as it gets, and I'm good for 10000 miles, give or take...
Whatever you do... do NOT buy a GF-4 based motor oil!
Plus (really knocking on wood here), I'm predicting the rest of the car to fall apart around the engine: starting with the autotrans...
True!
Engines last forever, since EFI became the norm - but trannies have ALWAYS been the bane of automotive enthusiasts. You can find old motors laying all over the place, however, go try and find an old tranny some time!
In my experience, an autotrans WILL last quite a while if you change the oil and filter every 15000 miles or so - dittos with manual trannys - but most ppl ride 'em til they drop...
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Oil change guys under-inflated my tires Formula413 The Lounge 26 06-20-2010 08:46 PM
Synthetic Motor Oil Change Interval trikkonceptz Off-Topic Tech 15 06-11-2008 10:08 PM
3000 mile oil change is a myth! SVOboy Off-Topic Tech 15 02-14-2008 03:43 AM
