Old 05-05-2008, 10:34 PM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
I never really thought about it, but why have the passenger side wiper? I have rainX washer fluid and it beads the water so I can see clearly anyway unless it starts to rain hard or I don't have my glasses on and it's dark, I only really need the drivers side one, visibility with the passenger side window is like looking out the side windows. It's pretty much easy to see. worst place is right in front of you.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 05-05-2008, 11:03 PM   #12 (permalink)
That's the main reason I asked the question.
Old 05-05-2008, 11:09 PM   #13 (permalink)
I think one big wiper would be hard to come by. So just having one might be better
I (used to) get rubber inserts for a dollar for my wipers. Just remove the old rubber, replace with new. Keep the old frames. It's $1 for a pair of rubber blade inserts. You cut them on the ends to fit, so It fits virtually any car. I spent 2 bucks on 4 wiper blades, screwed one up, got one for the rear (cut to fit) and 2 for the front (cut to fit). They're triple edge blades too. Worked out great until they stopped supplying them at the local big lots . I'll have to search them up right now!
Old 05-06-2008, 03:08 AM   #14 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Hmmm I do not think I could ever remove my wipers. I am not concerned about rain at all I can see rain coming. I am worried about those things you do NOT see coming. Splats and splashes where its get it off the window now or your crash :-) IE not worth it. I will aero the wiper first. I DO plan to remove the passenger wiper from Vger but I have huge 28" wipers and they "cross" each other. IE my drivers wiper almost reaches the other side of the windshield (I mean it too misses by some 10 inches maybe?)
Now what would be interesting is altering the REST position of the wiper! if I put the passenger wiper on the drivers side I could have the wiper VERTICAL against the edge of the windshield and have it move down the windshield and then back up IE where straight UP the glass is now the rest position. My wipers mount on the outer edge and swing IN so the wiper mount itself is almost completely to the sides of the vehicles. Use the passenger arm as well and I could even leave BOTH wipers intact and be able to easy aero them completely! MAN thats a good idea I am going to look into this tommorrow!!
Here is a really Q&D photoshop of what I mean Obviously this only works on cars like mine where the wiper mount is so far to the outside IE it would not be in my way looking out the windshield.
http://www.nerys.com/stuff/aeromod2.jpg
Old 05-06-2008, 09:52 AM   #15 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Some Mercedes have Single wipers, they are center mounted, and extend/ retract when in use.
I doubt it would be wrth the FE while, but it would be a cool swap in to a different vehicle.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 05-06-2008, 09:55 AM   #16 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Here having only one wiper is illegal anyway, you need to have 2.
Regarding the vertical positioning of the wiper, I'm pretty sure it would hurt more than help due to the impact on the A pillar vortex. But who knows without testing?
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-06-2008, 10:35 AM   #17 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
weight is only an issue in the design stage of the car i think. if weight saveing is a design goal in a new car design saveing some grams on every part and keeping all mechanisms simple and therefore light might reduce the overall weight. on the other hand most single wipers that cover the same area as double ones use a more complex mechanism, so theres not that much weight saved. so unless you already ripped out the interior and all seats and drilled holes in all non load bearing structures etc...don't think about the weight of a single wiper.
aerodynamic drag is another thing and more important although still marginal in relation to other areas of the car.The way wiper blades park and the blades themselves is more important than their number. a good wiper design should park outside of the airflow into a recess, the base of the windshield is a high pressure area so it's not as critical as other parts of the car but a fairing in front of the wiper that deflects the air over it is usually a good thing. also recently flatblade wipers have appears also as aftermarket add ons. these have an overall lower profile than conventional blades so they'll generate less drag when in use. i have used them and i'm quite happy with how they look and perform, they have a spoiler like top that performs pretty well at high speed to keeps the wipers stuck to the windshield rather than start to flutter , although this probably doesn't directly serve as a drag reducer the overall setup probably has less drag than normal wipers.
some racecars (and cars trying to look like them) have single wipers that park in upright position. perhaps these wipe better, but i assume the single wiper is for simplicity. an upright position in the center of the windshield won't add that much drag, an interesing example is the opel eco speedster wich was a concept car that set a diesel speed/economy record and was desinged for very low drag.
so if you're wipers are very exposed to the airflow pulling of a single wiper will arguably reduce drag, but will compromise wiper performance although this might be compensated fro with a single bigger blade that roughly clears the same surface
imho, installing a deflector in front of the wipers (for some trucks this is available as an aftermarket feature although mostely for looks i think) that shields them from the airflow as well as looking for flatblade wipers is the best way to reduce drag without compromising safety or running into legal issues.
if you have a coupé like hatchback with airflow attached to the rear window that has a rear wiper, pulling that off might create a slightly cleaner wake. and if the airflow is attached you won't really need the wiper anyway.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 05-07-2008, 07:48 PM   #18 (permalink)
If you remove the wipers until it rains anyway, wouldn't you be breaking the law?
Old 05-07-2008, 08:28 PM   #19 (permalink)
I've got 2 officer! They're just not...hrm...installed...lol
Yup I would be breaking the law. It was never my intention to remove them though. Too dangerous imho.
Old 05-07-2008, 09:20 PM   #20 (permalink)
Grrr :-)
Nerys's Avatar
Hmmm unaware it was illegal. I would never remove both (as I stated earlier the problem is when you NEED them right this second and did not expect too IE at 50mph its too late to go huh lets stop and put them on :-)
BUT it is a thought. and its not "all" about raw mpg gain its also about the "mindset" the idea IE making an effort even if it results in very small gains.
Dream Prius (aerodynamic mod exercise for 2nd gen.) bestmapman Hybrids 95 01-13-2012 02:09 PM
Swift brick? Tom.Wiley Aerodynamics 24 05-06-2008 04:41 AM
False windshield for boxy car? brucepick Aerodynamics 25 03-11-2008 11:51 AM
