Old 04-28-2011, 04:26 PM   #11 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
That is interesting. My 99 Wind star is rated about the same but gets in the mid 20s. It is only 2wd but it has a 3.8 v6 engine. Did you get a fuel mileage gauge? It takes effort with mild acceleration and letting it freewheel when coasting.
Noah Webster, 1787
Old 05-01-2011, 02:01 AM   #12 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by jtbo View Post
Today's high tech in car engines is 40 years old on ships, for example common rail injection, has been used in ships really long time before in cars.
You are thinking of diesel engines, where direct injection in many forms has been around forever. A diesel engine requires injection into the combustion chamber, or at least a pre-combustion chamber in early designs. I am talking about gasoline engines, where, while the technology definitely isn't new, it has only been implemented in the last few years. I think the VW 2.0FSI engine was one of the first engines to make GDI "normal". Now we are seeing this technology everywhere - VW, Hyundai/Kia, Ford and Mazda. Toyota and Honda aren't on the bandwagon yet but no doubt will be soon. From what I understand, GDI allows for highly statified charges, allowing overall leaner air/fuel ratios, by making the area nearest the spark plug rich enough to support combustion and the rest of the chamber lean - basically, a variable air/fuel ratio in the same charge. That's as best as I can understand it. A more apt description from someone else would be appreciated.
Originally Posted by notanarborist View Post
Wow, that's not very good mileage on the Escape for what it is. My wife and I are averaging 23.0 mpg on our 03 Town And Country with 3.8l with the occasional average going to 23.1(and this is with the odometer reading about 4% low).
That's exactly why I got rid of the Escape. "For what it is" is the reason. Such a small vehicle should get better figures. I attribute the ridiculously low economy to the poor transmission. A genuine slush-box in every sense of the term. The engine was always revving at 2500 rpm to even acclerate a modest amount in traffic because of so much torque converter slippage. I tried "freezing the slush-box" (see other posts about this) by overriding the torque-converter lockup, but the transmission would usually just go into a limp-home mode after a while. It sort of worked, but not well enough to make a difference. On the highway, it wasn't ridiculously bad - 25 mpg on road trips. It was just the city driving that was awful, again, because of the slushiness.
Old 05-01-2011, 07:12 AM   #13 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
GDI is WW2 tech:
Gasoline direct injection - Wikipedia, the free encyclopedia
Mitsubishi was first (1996) in this new coming of that old tech GDI, VW is latecomer to party.
Computer control and better manufacturing tolerances are giving new life to old tech, now we can unleash potential in them, but there really is not much new stuff going on.
Old 05-01-2011, 10:31 PM   #14 (permalink)
90 day: 19.36 mpg (US)
Improve it by getting rid of it. An old saying was "Jack up the hood ornament and slide a new car underneath."
Old 05-05-2011, 09:53 AM   #15 (permalink)
Wagon - '06 Ford Focus zxw
90 day: 29.69 mpg (US)
If you want another car with better FE and around the same cargo space I would look into a wagon, the toyota matrix is a really good one.
I personally got a ford focus wagon, look out for a 06-07 as they're rated 37mpg on highway (with a std transmission). They can be found cheaply (paid 5k for a 06 with 60k miles on odo) decently reliable, maintenance&tires will be cheaper than your escape.
You could probably sell your escape for around the same price as a focus and you'll get around the same cargo area.
Old 05-05-2011, 11:24 AM   #16 (permalink)
Twuck - '06 Ford F-150
90 day: 17.82 mpg (US)
Rudolph - '95 BMW R1100 GS
90 day: 35.37 mpg (US)
Terrifying - '02 Chevrolet Corvette Coupe
90 day: 28.4 mpg (US)
Big Red - '13 Ford F-150 XLT
90 day: 18.96 mpg (US)
Originally Posted by morphector View Post
If you want another car with better FE and around the same cargo space I would look into a wagon...
"SUVs are gross because they're the solution to a gross problem. (How to make minivans look more masculine.)" - Paul Graham, [Link blocked].
Me, I'll second the suggestion of the wagon, or maybe a modern minivan.
Old 05-05-2011, 10:24 PM   #17 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
People think they are getting a lot or cargo space in an SUV but they ain't. Not compared to a van.
You would think that a monster like the excursion would have a lot of space...
Ford Excursions offered 146.4 cubic feet of maximum cargo space. This is the most capacity ever offered in a full-size SUV
The Ford Excursion was too heavy to qualify for mandatory EPA testing, so there is no official mpg rating for the vehicle. Its curb weight is 7,361 lbs.
It got about 12 mpg.
Previa Van: 152.3 cu ft cargo space. Curb weight 3600 lbs. 17-20mpg epa
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
Christ (05-05-2011)
Old 05-05-2011, 11:57 PM   #18 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Marcus, that is an awesome post. It makes a great point about how people can be misled to think that something physically larger in mass/ volume must also be better in every aspect.
Old 05-06-2011, 04:02 PM   #19 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Thanks Christ,
I might also point out how insecure someone must be to buy an SUV instead of a minivan because they think minivans are not masculine enough. A man is defined by his actions not his outward appearance. But who am I to rob someone of their need to compensate?
ps. This is not aimed at anyone here, just a general observation.
Christ (05-06-2011)
Old 05-06-2011, 10:13 PM   #20 (permalink)
OldContinents
Works with cars too, modern bloated cars are really big from outside, wide and tall, but there is less interior space than earlier models of same car which had smaller outer dimensions.
All the unneeded huge plastic 'decorations' are taking really big part of space from inside.
So in that way progress has been going backwards.
The Following User Says Thank You to jtbo For This Useful Post:
Christ (05-06-2011)
