EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Ordered/Installed: Perforated White One Way Overlay (https://ecomodder.com/forum/showthread.php/ordered-installed-perforated-white-one-way-overlay-32374.html)
deejaaa 07-15-2015 01:53 PM
this is not printed so will be white. should have extra so if someone else wants to give it a shot I can send some your way. I just ask you to use it and not set it on a shelf. will see if this keeps me a little cooler on the drive home. will last a few years. plan to use on back window but might also try on the sides. only concern is the rear facing DVR.
http://i110.photobucket.com/albums/n...psssmyizzu.png
http://i110.photobucket.com/albums/n...psgb1za6ta.png
http://i110.photobucket.com/albums/n...psnme59fhy.png
http://i110.photobucket.com/albums/n...psyeoyjduc.png
Xist 07-15-2015 02:21 PM
How much would I need to cover my car? :)
whatmaycome14 07-15-2015 04:07 PM
What a brilliant idea! Keep us updated if this keeps the interior temperature lower. If so, I'll order some right away!
freebeard 07-15-2015 04:09 PM
Xist -- If the windows are ≤26" you'd have 10 feet. If you have thick C-pillars or you can overlap the side window pieces you might get the side windows and backlight out of a full sheet.
deejaaa 07-15-2015 08:30 PM
not shipped yet but Estimated delivery Fri, Jul 17 - Fri, Jul 24. the 26th i will be heading out of town, to Kindersley, SK. CA. will be gone 3 weeks. might not be able to give impressions till i get back if it's here the 26th. coming from NY.
oldtamiyaphile 07-15-2015 09:00 PM
Why not just use window tint?
deejaaa 07-15-2015 09:17 PM
double it? i already have tint. this goes on the outside.
Xist 07-15-2015 09:46 PM
Interesting. Would you have more visibility with illegal tint instead?
Laws are weird...
deejaaa 07-15-2015 10:41 PM
won't know until i try it. i have legal on the back so that will be a good gauge.
oldtamiyaphile 07-15-2015 10:59 PM
Laws are weird...
This stuff is only legal on windows that don't have a tint limit (rear and rear side windows), that is you could just go to a darker tint for a similar effect. It's not away around tint laws.
Looking at the pics it looks like about 40% light transmittance. If you add this over 40% transmittance tint, you'll have roughly the same effect as if you'd just gone with 15% transmittance tint.
Although the white colour is good for reflecting light, tint films have metallic particles added which serve a similar purpose.
Unfortunately it's going to be a hard thing to test properly unless you have two identical cars.
