Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-13-2024, 04:17 PM   #11 (permalink)
Originally Posted by Logic View Post
I was asked to have a look at a stove-oven recently and was flabbergasted to discover they have chimneys!
And what seems to be air intakes below the glass window in front.
So; heat the oven at great expense,
then
exhaust all the hot air out into the kitchen.
Then
cool the kitchen at great expense!
I was flabbergasted! I was angry!
I was shoving pot scourers into that scam-ney as fast as I could!
I was happy to hear that my friend's electric bill had dropped even more than the temperature in her hot kitchen!
Ya that's why if you're cooking something in the oven and have optical smoke detectors near by they'll false alarm when you're cooking something, without even opening the oven door.
"Eco mod my oven"?
Old 09-14-2024, 05:24 PM   #12 (permalink)
Actually it has 2 fans, ONE "circulates" the interior, the other cools the electronics either computer, mosfet or igbt. Apparently the inner one causes a faster cooking process for things that tolerate air flow or items that prefer a dryer process. Evens out the temperature through the oven. Works a treat on baked goods and chicken.
Oddly it only has an inch of fiberglass mat between the oven and control electrics and nothing between the transducers to control board
So there's no chimney venting hot air out the oven, but there is a fan to mix hotter air collected at the top with the cooler air lower down
and because you get more watts (heat) into whatever you are cooking if you thin the boundary layer there by moving air..??
I have no problem with that.
But any chimney that lets a significant amount of hot air convect out fast needs to be slowed down.
Does this fan blow down from above?
Old 09-15-2024, 12:57 AM   #13 (permalink)
Originally Posted by Piwoslaw View Post
And this might be the closest to the purpose of the chimney: To allow air, especially moisture, to escape. Otherwise it might condense somewhere inside, which is not good.
That's why I used to keep the door of the oven open for a while after using it, so any steam would easily escape instead of condensing inside.
