12-28-2010, 07:15 PM
#51 (permalink)
Update: I have checked and added pressure to my tires and will report my fuel mileage results over time.
Old pressure- 40/38 psi
New Pressure- 44/41 psi (44 is sidewall max)
So far I have not noticed any negative ride or handling characteristics. I may experiment with higher pressure if the MPG results are promising enough to justify it.
12-29-2010, 10:23 AM
#52 (permalink)
the crazy guy in back
Cressy - '90 Toyota Cressida Pickup - '91 Toyota Pickup base
bead-tearing: I've seen more sidewall damage running underinflated tires than overinflated. either way the tire won't fall apart from it unless the person doing the demounting screws it up. I worked in a tire shop the last 2.5 years. For liability reasons we couldn't inflate over the sidewall max and unless the customer specifically asked for it weren't supposed to go over the placard (tho I usually did a little) I've never had trouble going over the placard but under the sidewall.
inflations effect on economy: it will always increase straight line steady speed economy, it's just a matter of how much. after a while it's a diminishing-returns scenario. Truck tires at 110psi vs passenger tires at 35 psi...35 to 44 psi is almost 25%. the same increase in a 18-wheeler wouldn't be an extra 9 psi but an extra 28..almost 140 psi. Again, diminishing returns since the semi-tires are run higher to start with relatively speaking and are constructed for capacity and RR more than comfort and grip. they're factors, but far less so than passenger car tires.
Even among car tires and cars themselves, the amount of margin is going to be different for every tire and even sizes within tires. there's no one set amount that works for every car equally. My moms buick responds brilliantly to increased pressure, however my 1/4t pickups don't notice (measurably) anything over 30 psi. BUT it's almost 150% of the placardmy mom's buick is a 60/40 weight split 3800lb empty car with a placard rating of 30 psi, my truck weighs 2800lbs with 35 psi on the placard.
02 Lesabre @ 30 psi=30 mpg hwy doing under 65 mph empty or 1 passenger
02 Lesabre @ 44 psi=35 mpg @ 70 with 3 ppl and 300 lbs of luggage
I've seen cars with noticeable underinflation wear AT the placard pressure (early 2000s mitsu diamante IIRC at 28 psi front + rear) the placards are first and foremost for comfort, second for safety, third for FE.
I would bet placard pressures come up a lot in the next few years. CAFE is supposed to be up to 35 mpg by 2018 (with increments before then) which is putting a lot of pressure (no pun intended) on the manufacturers.
In Summary: yes you can go over the sidewall ratings, but it's your a$$ on the line, the numbers are to keep their liability down. I recommend somewhere between the placard and the sidewall, leaning on the higher side.
-2003 Subaru Baja 2.5 5MT
-2005 Subaru Baja 2.5T 5MT
-1994 Pontiac Firebird 5.7 V8/6MT
-2001 BMW R1200c
-1970 VW Beetle
-2015 Prius (for the wife)
"You don't get to blame me for how I fix what you broke."
12-29-2010, 12:16 PM
#53 (permalink)
I recently got some of the Bridgestone RE92's, the Insight ones, 165/65-14. They tire place put them at 30psi and I drove home, it didn't feel right. As soon as I got home I put them at 50psi and they felt much better. 400miles later I needed to take one off for another reason, so I inspected the tread wear. The center rib of the tire still had the little nubs left on it from the wiskers, the outer ribs did not, even at 50 psi the center rib was not seeing the same amount of wear as the outer ones, hmm....
12-29-2010, 01:38 PM
#54 (permalink)
That's crazy!?!. Are you planning to change psi around to see how it affects mileage/ride?
12-29-2010, 04:11 PM
#55 (permalink)
Maybe when it gets warm
12-29-2010, 04:27 PM
#56 (permalink)
I have gone through 148k miles worth of RE92's on my 2000 Insight. This is the CLASSIC wear pattern. All this time I thought it was the car, not the 50 psi. tire.
12-30-2010, 02:50 PM
#57 (permalink)
So then, maybe 55psi will even up the wear?
12-30-2010, 04:18 PM
#58 (permalink)
I don't think so, but good luck.
12-30-2010, 04:21 PM
#59 (permalink)
60+psi!!!! LOL!
