Old 06-15-2009, 03:54 PM   #1 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Cool BMW developing thermoelectric generators
...and say they'll be in their cars in five years.
Linky; BMW thermoelectric generator technology
-Terry
Old 06-16-2009, 10:30 AM   #2 (permalink)
Knowing BMW, it'll have a 500 hoses each with at least 2 failure points (sometimes 3), it'll cost $10,000 to replace, you'll need a $100,000 dealer only tool to diagnose it, you won't be able to service it without dropping the engine and like all new first generation BMW technology, it'll cause the car to depreciate faster than yesterday's newspaper.
Old 06-16-2009, 11:08 AM   #3 (permalink)
Interesting read Terry. As we know here, current TECs are incredibly inefficient (usually under 10%). Theres no saying you can't use them, but its most likely cost prohibitive. So, BMW is going to have their work cut out for themselves. They're going to have to improve efficiency, and/or cut cost quite a bit I'd think.
Old 06-16-2009, 01:23 PM   #4 (permalink)
I guess bmw realized their last idea was retarded.
Old 06-16-2009, 01:39 PM   #5 (permalink)
Most of the article is sloppy, and this is absolute gibberish: "Recycling this abundant energy source would require replacing the plutonium in a RTG with a non-hazardous material that conducts electricity while resisting heat, not an easy task since most metals become hot when a current is applied to them."
Say what?
As mentioned, TEC efficiency sucks. I like the dual stage heat engine idea much better.
Old 06-16-2009, 02:31 PM   #6 (permalink)
Deadly Efficient
So, tjts1...tell me what you really think of BMW...
I agree some of the things they try are pretty silly. But I give 'em props for trying. Not like our domestic automakers.
I think a lot of times the 'five year' time line is used as a way to let a failed idea die quietly without anyone noticing.
-Terry
Old 06-18-2009, 05:10 PM   #7 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
A huge amount of energy exits the car via the tailpipe, and it makes sense to try waste heat recovery. Honda tried the heat engine approach too: Green Car Congress: Honda Researching Advanced Hybrid Drive with Rankine Cycle Co-Generation.
When attached to the 150HP engine in the Honda Stream mini-minivan:
Maximum power available from the volumetric expander is as much as 32kW (43hp), and maximum thermal efficiency of the unit is 13% at 23kW (30hp). In comments following the presentation, Yamamoto indicated that Honda would need to see higher efficiencies achieved with the system if it is going to be considered for production.
Waste heat recovery systems might pay for themselves on heavy duty and stationary engines, but even Honda, who are obsessed with fuel economy, think the benefits of this waste heat system are outweighed by the cost, weight penalty, and complexity.
ThermoElectric Radiator trebuchet03 EcoModding Central 5 04-02-2011 04:10 PM
Germans trying to replace Alternator with Thermoelectric Generators or TEGs 88CRX EcoModding Central 24 03-13-2009 02:13 AM
VW Golf with exhaust thermoelectric power: +5% MPG MetroMPG EcoModding Central 25 03-04-2009 03:17 PM
Article: BMW Plans All-Turbo Line RH77 General Efficiency Discussion 2 10-10-2008 12:10 AM
vortex generators at rear bumper?? crexcrex Aerodynamics 14 08-22-2008 05:11 PM
