Old 08-14-2008, 10:38 PM   #1 (permalink)
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
Scangauge doesn't work
I tried to put the scangauge in the suburban and it doesn't work. I plug it in and it doesn't get any power. The screen stays dead. It works fine in everything else. I double checked and it worked fine before and after the suburban.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 08-15-2008, 03:36 PM   #2 (permalink)
Smile
Make sure that you don't have a blown fuse in your Suburban. This MAY be the cigarette lighter fuse, but I am not 100% sure.
Good Luck,
Wayne
Old 09-01-2008, 10:49 PM   #3 (permalink)
lovemysan's Avatar
I called tech they suggested the fuse also. It was a blown lighter fuse causing the issue.
2002 Saturn SL
sohc + 5spd = 50mpg
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
ScanGauge is bad for MPGs Tango Charlie The Lounge 2 08-10-2008 12:29 PM
Scangauge Malfunction ??? trikkonceptz Hypermiling / EcoDriver's Ed 3 06-22-2008 02:04 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
