Old 04-13-2013, 02:53 AM   #1 (permalink)
P&G - how wide of speed is needed?
Much of my driving conditions are moderately loaded highway - not necessarily rush hour, but no way in hell can I slow down to 40mph. How "narrow" can you effectively P&G in and how much does it affect your overall efficiency? Would even like 65mph->75mph work?
Old 04-13-2013, 03:39 AM   #2 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Depends on your car aero, but I think 65-75mph is too fast - glide is not long enough, it is probably better to just use steady 70mph speed.
55-65 or 50-65 would be better.
YMMV
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
Old 04-13-2013, 04:18 AM   #3 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
I've gotten great results in my car, extending the "glide" phase with very light gas pedal pressure... IE, getting up to 65, then slowly decelerating to 50ish. The glides last almost forever and I can easily break 100 MPG the whole glide portion. I don't know how flat your roads are, but I have gotten my best results (and least stressful for me!) by just watching the lay of the land, and using it to my advantage--that is to say, "gliding" with light power up hills, then regaining lost energy on the downhill portion.
Even moderate slopes on highways give great results. My highway trips are usually 50MPG+
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
Old 04-13-2013, 08:57 AM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I go 55-65 generally, and sometimes 50-65. Forty is too slow on a freeway and you might cause an accident if it's crowded or get a ticket when it's not. I have also had good results doing P&G with the engine on. Here is a test I did: http://ecomodder.com/forum/showthrea...tml#post252933
PaleMelanesian (04-17-2013)
Old 04-13-2013, 10:37 AM   #5 (permalink)
If you have any elevation changes use them to accentuate your P&G. The road I get on when I leave my neighborhood runs parallel with the railroad tracks which are basically level. I'ts an excellent teaching tool for gliding when you can see the road drop compared to the RR tracks. Coasting distances can easily double when you do it downhill, even when the downhill portion is very a slight grade.
Perfection would be where you can coast downhill and pulse uphill at best BSFC, without any change is speed whatsoever. That would allow you to avoid the exponential increase in aero drag in the pulse portion on flat ground. This has proven to be the best scenario for highest mileage in contests.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
ECONORAM (04-17-2013), PaleMelanesian (04-17-2013)
Old 04-13-2013, 10:40 AM   #6 (permalink)
I like a 10mph drop in speed before accelerating on the highway, 15 is great if you can get away from it. However, in town I find that 5 mph can be quite a long glide.
The Following User Says Thank You to Daox For This Useful Post:
Old 04-15-2013, 08:39 AM   #7 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I can happily use a 5 mph span in tight traffic. 10-15 mph is what I generally do on the highway when conditions allow. On backroads with no traffic and no rush? PSL+10 down to below 20 mph.
Transmission type Efficiency
Old 04-17-2013, 02:29 PM   #8 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
I saw several MPG gain going from 45-55 down to 40-55. 55 to 50 drops fairly quick. 50 to 45 takes probably 50-100% longer. 45 to 40 takes probably another 50-100% from 50 to 45! If it's even a tiny downhill slope, I could be going ~43MPH the whole way down! I'm sure every car/road is going to give different result, but I definitely found 15MPH between P+G to be the way to go.
Old 04-17-2013, 02:57 PM   #9 (permalink)
Back when I P&G'd out in the sticks I went 60-25 with the Coupe. 25 was about as slow as I cared to go in 5th. Made for a gentle bump start too.
Old 04-17-2013, 03:44 PM   #10 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
on the highway I love 60mph to 40mph
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
