Old 03-12-2015, 10:49 AM   #11 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
On the road I drive the grooves are made by large trucks and the roads are in awesome shape. The grooves are double tire wide which allows for a bit more freedom. In the wet I ridge ride. I can tell a difference for sure when I ride in the grooves. Its quieter and smoother. It is also an inch or so lower than the ridges.
Would not this effect be like lowering the car the equivalent amount as the chassis is actually closer to the ground?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 03-12-2015, 05:23 PM   #12 (permalink)
ShinyMew's Avatar
Suzuki Swift '06 - '06 Suzuki Swift (Base)
Correct me if I am wrong, but I always thought the idea of ridge-riding, as it applies to wet weather, is to drive along the ridges and thus outside the grooves where water pools and creates extra drag?
Proponent for Prevention of Cruelty to Automobiles.
Old 03-12-2015, 05:25 PM   #13 (permalink)
Got MPG?
Yep. That is what I said. In the wet I ridge ride, in the dry I groove ride.
Old 03-13-2015, 03:34 AM   #14 (permalink)
90 day: 29.78 mpg (US)
Seems like something better tested than speculated on. Anyone for some ABA?
dry weather, inside lane, outside lane, ridge-riding, side of the road
