Old 03-11-2018, 04:00 PM   #3151 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by mora View Post
Does somebody have the latest bill of materials for the AC control board? I thought I had one in my email but I didn't! About time to get the board populated.
I have a BOM for my version of the AC controller (serial number 2) so it will be close to what you have, but I don't have an updated BOM.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 03-11-2018, 04:03 PM   #3152 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Mine doesn't even have serial number It is version 0.3.
Old 03-11-2018, 06:44 PM   #3153 (permalink)
I guess .. if it HAD a serial number .. it would be 002. I'll have to look up what the version is.
Old 03-11-2018, 06:56 PM   #3154 (permalink)
I spoke too soon. It seems that Paul made up a BOM and shared it with me with a link. But it's just for a single IGBT driver, not for the whole AC board. Sorry
BTW, the artwork for the AC board shows rev 0.3 for my AC controller, so it should be the same as mine
The Following User Says Thank You to thingstodo For This Useful Post:
mora (03-12-2018)
Old 03-13-2018, 01:17 AM   #3155 (permalink)
I powered up the AC controller today with just control power. It printed the powerup message
AC Controller firmware ver 1.0
Throttle out of range! Is it unplugged?
Which, of course, it was. So I powered it down and looked up the pinout (5V, Gnd, Throttle - seen from the edge of the board, looking toward the IGBTs) .
Connect a throttle - a Honda civic hall effect throttle. 5V to pin 3, Brown. Gnd to pin 2 Blu. Throttle to pin 1 yel. Power up the board - same message.
Power down and remove the throttle signal from the controller pin. Power up and check the throttle. 1.00V minimum, up to 4.6V at full throttle. Looks fine.
Start up the controller and begin logging the raw throttle and the scaled throttle. 0000 raw, -4051 for scaled ... that's weird.
Put the throttle signal onto the controller while logging. No change on the logging. Measure the voltage - it is now -0.16V referenced to the throttle ground. How?
Tried the other channel on the Honda throttle. After powering off and moving wires around - 5V to pin 6 Grey, GND to pin5 blu, throttle to pin 4 purple. Disconnect throttle from the controller. Power up. 0.51V minimum, up to 2.33V at max. 1/2 of the other channel. Makes sense since they are supposed to be related.
Connect the throttle signal up while logging and the controller stopped. Looks like it did a reset. I may have touched the 5V signal, but the input should be high impedance - right? it's a hall effect throttle - not much current available!
Paul - any troubleshooting advice?
I think I will order some pin headers so that I am not tempted to use small gator cordsets for this type of stuff. Hopefully I didn't break anything
The logging still lists 0000 and -4051 for raw throttle and throttle. It's almost like the input pin is tied low with a low resistance ... except that it goes below 0V?
Old 04-11-2018, 04:07 PM   #3156 (permalink)
PaulH
MPaulHolmes's Avatar
I have checked the splines on the EM61 (I think that's what it is) and the EM58 Or whatever it's called, and they both are the same.
thingstodo, did you get the hall effect throttle working?
kits and boards
Old 04-11-2018, 04:48 PM   #3157 (permalink)
Not yet Paul. Setting up the controller in my basement so I don't have to spend 2 hours re-arranging vehicles in my garage every evening to get 15 minutes of testing done
I will post if I get it working
Old 04-13-2018, 11:51 AM   #3158 (permalink)
PaulH
It worked fine, but the issue was, I couldn't spin it very fast because of my crappy alignment. I didn't do a very good job of welding on the spline. I need to get it professionally done.
kits and boards
Old 04-22-2018, 12:08 AM   #3159 (permalink)
Trying to get a small motor running with AC controller.
Controller powers up, I have a decade resistor box working for the throttle.
I'm logging - things look fine.
I'm having a senior moment ... run-pi-test ... do I need to press the throttle after that? It just kinda sits there.
Old 04-25-2018, 07:24 PM   #3160 (permalink)
PaulH
Try "run-pi-test2". This works better, and I think it's implemented in what you have. if it's not I can implement it. It basically lets you get a visual inspection of the convergence rather than letting the computer see if it's converging.
kits and boards
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 11:55 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 02:59 PM
