Old 03-18-2010, 09:43 AM   #11 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The yellow goo is water mixed with oil, you most likely are seeing this on the underside of your oil fill cap, correct?
Does your engine ever fully warm up? you could also install a block heater to help it warm up, or because you are driving short distances... bike or walk instead.
Old 03-20-2010, 10:37 AM   #12 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
I have been driving with the new PCV valve for a couple months now with no problems. I have even taken it apart and checked frequently. I can't tell any difference in the running of the engine, but as a $5 fix, I don't think I could go wrong.
Also, I primarally drive my car to and from work, about 13 miles one way. I won't consider biking based on the narrowness of the roads and the aggressiveness of the drivers.
air filter, pcv valve
PCV catch can install. Goldenfrog EcoModding Central 50 06-14-2016 11:30 AM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
little help.. newbie mechanic metro valve cover an0nymous Off-Topic Tech 5 04-13-2010 04:13 AM
DIY- Setting Valve Lash for Honda SOHC Motors TomO DIY / How-to 7 05-27-2008 10:21 PM
