Old 12-17-2009, 07:40 PM   #1 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
little oven element
I was looking over the little convection oven I have and fond four elements. 2 are used to go to 450F then four...
I ponder making a heater, all in one for the car.
I have yet to figure the fairy tale with 12volts. it can be alot bigger than what we are constipated with.
I am thinking power invertor, little element, about 300watts, I mean tiny element, it is a bout .25 diameter by less than 12X10 shaped in a "u". A metal lined whatever box..
anybody done this? I also ponder a .25 amp computer fan, to mimick a convection, or flow to start then let it get sucked into car recycle vent (I have mine 50/50 outside/in permanent)
I was hoping to do this before the melting glaciers killed me with hypothermia in a heated room..
Old 12-17-2009, 09:27 PM   #2 (permalink)
How about one of the pre-made dealies for that? Anything connected to your cig. lighter socket is going to be limited to under 150 watts because that's all the socket can supply - but there are some direct wire ones good for almost as much as a household space heater.
12v heater - Google Product Search
Work From Home mod has saved more fuel than everything else put together.
Old 12-17-2009, 10:38 PM   #3 (permalink)
What's your goal here? What are you trying to heat?
Honda Element 2 front end mods hans2vt Aerodynamics 10 12-24-2014 03:45 PM
Honda element, vw beetle, jeep wrangler... hans2vt Introductions 9 05-08-2009 04:05 PM
Toaster Oven Fowl trebuchet03 Saving@Home 9 01-21-2008 08:33 AM
