Old 02-21-2023, 05:38 PM   #11 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Regarding the app I use, it is called ArtFlow.
The 3D app is called Prisma3D.
I'm using both on a Note8.
Caddylackn : Great advice.
This is just a "what if" doodle. I have no real plan to create this.
However, if I did, I would do something similar to what you mentioned.
The windows would raise as far as they could go, and any gaps could be filled in with something custom.
I have a 3d model of the car that is accurate.
It would give me an idea of how far off the windows would be with the roof laid back.
The Following 2 Users Say Thank You to Cd For This Useful Post:
aerohead (02-23-2023), freebeard (02-21-2023)
Old 03-09-2023, 12:15 PM   #12 (permalink)
NISSAN Z-Car roofline
I finally located a photograph for wind tunnel smoke-flow imaging of the 2020 NISSAN 370-Z ( I'd originally found it online ).
Three smoke filaments are presented.
The second-lowest makes contact with the boundary-layer on the windshield, over the top of the roof, an then separates immediately beyond the roof apex.
The 370 is 1,315mm high, and based upon the 'daylight' between the trailing edge of the upper body, and the local streamline, there's a 82mm separation gap.
A first-approximation solution for reattachment would be a shallow, upswept rear spoiler, with its tearing edge just touching the bottom of that streamline.
Dr. Hermann Burst might have recommended lofting the entire rear contour up to this imaginary line connecting the span.
