Old 09-29-2010, 11:47 PM   #11 (permalink)
90 day: 19.36 mpg (US)
This who you want to consult with:
Swain Tech Coatings for engine piston coatings, race engine coatings, ceramic header coating, carbide metal coatings, thermal spray plasma coating, metalizing closures, spray welding
Are you sure it's a Model 9? They haven't been made since 1962.
Old 10-02-2010, 06:26 PM   #12 (permalink)
EcoModder Newbie
GTA - '87 AMC GTA
2k6 Silverado - '06 Chevrolet Silverado LS
Send a message via ICQ to PhilA Send a message via Yahoo to PhilA
I'd say ceramics inside there- avoid Teflon, if the engine is a vintage like that it'll never stick to anything properly and flake off, fouling things up.
Sad as it may sound, the most efficient small engine I had ever run was close to worn out. I gave it a set of new rings as the compression was low to try and avoid blow-by, ground the valves so they sealed tightly... the rest of the engine was terrible by modern engineering standards. That said because the tolerances were so high, every moving component had scores they sat in, and with 10w/30 oil it had so little running resistance I could stop it with two fingers on the flywheel at idle. It also burned oil from the sump which appeared to help at low-to-mid engine speeds.
The exact same model engine I fitted to my scooter (see Motorbike thread) was tight, accurately machined and still used more fuel when put onto the same application (lawn mower, not the best gauge of it, I'll admit but that was a constant load situation)...
Should do well with ceramics though internally
--Phil
idea, 4 cylinder to 2 cylinder engine conversion saand EcoModding Central 152 01-02-2016 04:33 AM
Geo Metro 1.0L G10 engine rebuild mods for better MPG Wonderboy EcoModding Central 54 03-05-2015 02:05 PM
Wonderboy's Metro XFi Revival Wonderboy EcoModding Central 44 01-29-2010 10:29 PM
