Old 06-01-2009, 09:45 PM   #11 (permalink)
Hi,
For my car, it definitely is dish out. I would think that flat or convex would be the best choices, and never concave...
Old 06-01-2009, 10:30 PM   #12 (permalink)
It appears we have semantic problems here.
"Dish in" could mean the concave part of the pan is pointing towards vehicle centerline, and it could mean the concave part of the pan is pointing outwards, if one is referring to it when assembled to the wheel.
I think either one could be viewed as equally correct.
So I'd go with "concave" or "convex" as installed, to describe it.
IMHO, "concave" is never the way to go for wheel aero.
Old 06-02-2009, 10:33 AM   #13 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
Frank, that was my opinion, not fact. My point was that you don't want to add frontal area by adding a big outward bulge to your wheels if they already sit at or outside the fenders. I agree that the convex shape is inherently better for aero on a wheel itself.
Furthermore, we are talking about these things like they have a smooth curvature to them. But I'm willing to bet these pans just have a harsh step on the rim like every other pizza pan. So you either have a flat wheel cover that sits a 1/2" outside the rim lip or a 1/2" inside. Is the small region of turbulence caused from placing them inwards worse than the added frontal area of placing the pan convex?
Old 06-02-2009, 11:56 AM   #14 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Anyone with pans care to A-B-A test?
Old 06-07-2009, 12:26 AM   #15 (permalink)
is not covered in bees.
Istas's Avatar
Honda - '05 Honda Accord EX
90 day: 27.16 mpg (US)
Insight - '00 Honda Insight w A/C
90 day: 66.55 mpg (US)
Send a message via AIM to Istas
My thought is, whichever gives the smoothest profile over the tire itself. I would line it up so that it's flush with the plane created by the outermost bulge of tire rubber. This would make me think that mounting it "convex" (bulging out away from the car) would be best in most situations, unless it's a very deep pizza pan, or a very narrow tire that doesn't really go past the edges of the rims. (I would try to avoid a deep pizza pan anyway)
Just my two cents, I'm by no means an aero expert.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
Where to get a 15" stainless or aluminum pizza pan? Chris D. DIY / How-to 12 12-14-2009 09:58 PM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
Getting Take n' Bake Pizza without using gasoline bennelson DIY / How-to 15 06-07-2008 02:41 AM
