Old 05-30-2009, 05:31 PM   #1 (permalink)
pizza pan - dish in or out?
Is it generally better to install pizza pan hubcaps dished in or out, or what does it depend on? Thanks
Old 05-30-2009, 06:55 PM   #2 (permalink)
These guys know what they are doing.
Old 05-30-2009, 08:31 PM   #3 (permalink)
thanks
the pic says it all I guess
Old 06-01-2009, 06:37 PM   #4 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
Careful though. Whats your wheel offset like? (tire to fender line-up?)
Old 06-01-2009, 07:54 PM   #5 (permalink)
wheel offset
It's a 1996 S10 pickup.
The outer rim of the wheel is about 2" in from the fender, as viewed from the top, less if viewed from the side, as the vehicle body tapers in as we descend. I hope I have understood "offset" correctly.
Old 06-01-2009, 08:21 PM   #6 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
With the dish in, the air only has to go over half a ridge, and it winds up about level with the tire sidewall. That will be closer to optimum.
Old 06-01-2009, 08:55 PM   #7 (permalink)
inny/outy ?
We'll have to make sure we're all defining "dish in" and "dish out" in the same way. When I say "dished in", I mean the center portion of the pizza pan is lower, or nearer to the hub of the wheel. When I say "dished out", I mean one is looking at what would be the bottom of the pizza pan (when it is installed on the whee). The center of the pan/hub-cap is further away from the hub of the wheel, like on the photo of the car a few posts ago. Have I got the terms right, or backwards? And are we all on the same page?
Old 06-01-2009, 08:57 PM   #8 (permalink)
source for pizza pans
I just bought 4 16" aluminum pizza pans from Russell Foods in Saskatoon, Saskatchewan, Canada, in case anyone is looking. They were about $6 a piece. They also had 15" and a size around 12 or 13".
Old 06-01-2009, 09:13 PM   #9 (permalink)
My thought was this: If your wheels/tires sit well inside the fender, then it makes more sense to have the dish out. This is the case with the VW above. This way you are keeping closer to a flush wheel and fender situation. However if your wheels/tires extended past the outer edge of the fender at all, dished IN would definitely be better, so that you are not adding any more frontal area.
Sounds like you should probably dish em outwards.
Old 06-01-2009, 09:29 PM   #10 (permalink)
Deez, you don't know that.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
Where to get a 15" stainless or aluminum pizza pan? Chris D. DIY / How-to 12 12-14-2009 09:58 PM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
Getting Take n' Bake Pizza without using gasoline bennelson DIY / How-to 15 06-07-2008 02:41 AM
