05-26-2008, 09:39 PM
#11 (permalink)
EV OR DIESEL
There is a 3 cylinder turbo diesel (1.2?) from vw. gets mid 70's in a Polo.
also a 1.4 tdi.
I'm a fan of the 1zz toyota also, but don't know how it would do mpg wise.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
05-26-2008, 09:49 PM
#12 (permalink)
nut
the swift gt has a dohc engine instead of the sohc engine that is in the normal 1.3L and it has a lot more aggressive cam. Plus the sohc has 3.52 gears compared to the 4.39 i think in the dohc.
It would be a pretty easy swap to get a 1.6L rwd tracker/sidekick and stick it in pretty much anything. They are small engines and fairly common. Plus you could always find someone to grind the cam down to a lower lift and duration to give it more bottom end power than stock and put 2.73 rear end gears in it for really nice tall gearing.
But a 3 cyl would be much more unique in that car. You could always put a second one in to double the power when you need it
05-26-2008, 11:19 PM
#13 (permalink)
Nice thing about a diesel is that they easily can be juiced up for short bursts using propane. Since they operate on excess air the auxilairy fuel is blowtorched into combustion by the diesel. The trick is getting the injection rate right and not advancing your injection when on propane.
The effect is like that of a gas engine on nitrous.
The M-B (Sprinter) engine can take the additional pressures. The VW might be iffy.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
05-26-2008, 11:42 PM
#14 (permalink)
EV OR DIESEL
I have no Sprinter High performance experiance, but the vw 1.9 motor is highly reliable to 200 wheel hp (300 tq), will do 250 in a daily driver, and 300 has been done. No need for propane, just Big nozzles, a tune, and a turbo if you want to make big #'s for long periods of time (keeps egt's down). the 1.2 can be hot rodded, not sure how/ how much.
The 1.9 Vw is 36x lbs ready to run the 1.2 is 19xlbs ready to run.
Any idea on sprinter engine weight?
That being said, If the car was heavier I'd definitely be gunning for the Sprinter (great motor), and obviously it all depends on performance expectations, the sprinter motor would need crazy gearing, the vw would be more normal . . . .
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
05-30-2008, 11:58 PM
#15 (permalink)
I could think of quite a few fun nissan engines.
cd17 diesel
sr16de (hard to find)
sr16ve (sweet revving engine)
sr16ve N1 (only 500, front drive)
sr20de (there is a 160hp version of this that has some type of valve or cam timing system for the 240sx)
sr20ve
Personally I'd go for a 200hp sr20ve, variable valve timing, 10-1 comp, header, exhaust. Should put down 180whp with a good header intake and tune. You could use 240sx trans.
05-31-2008, 12:33 AM
#16 (permalink)
Another possibility would be the Mercedes-Benz I-5 turbodiesel out of a Sprinter van. These are just now becoming available at recycling yards. Sprinters get fabulous mileage but as a van they are slow, slow, slow. Getting the DIN bellhousing to match up to your Japanese transmission might be a machinist's nightmare. You'll need to regear the rear axle. Details, details.
An engine that gets nearly 30 MPG out of a van should give you staggering MPG in a Z.
have fun doing that swap.
Here is what you could put in that is from a Mercedes and is diesel.
the OM617.952 is the famous 5 cylinder turbodiesel with the iron head. Indestructable but slow. It can be modified to get more power ( www.superturbodiesel.com ) The finnish have gotten close 300 hp out of this 5 banger
The OM60x series ( OM601,602,603 or the 606 twin cam)
the 603 is found in the 86/87 300SDL, the 601,602 are the same as a 603 but with one or two cylinders loped off. They are all mechanical injection but do yield a solid 30 mpg on the highway. The 603 will give 30 on the highway in a big S-Class. The smaller engines will yield more because they were put in smaller cars. They do have one computer for idle and EGR, IIRC. Finnish have squeezed 400 hp from this one
Downside of this engine, the head is aluminum and if overheated the head likes to warp or crack. So records are a must. Plus some of the early cast heads are said to be more prone to cracking (#14 head IIRC) so some upgrade to the #22 head.
The big daddy, the OM606 is found in the later W124 chasis E300D's and are non turbo's. They recieved a turbo in the E300D ( W210 chassis) in '98 and in the '99 model year and will give a low 30's to mid 30's on the highway if driven normally. The downside is the injection pump does not have a mechanical govenor, but the finnish( diesel tuning gods) have proven the OM603 injection pump can be used on the 606 with no ill effects. Tuned properly it will put 500+ hp and ooooh soo much torque to the wheels
However, the biggest drawback on this the glow plugs. They sometimes like to get stuck in the head and snap off. This is largely due to the fact they are longer than the plugs used in the 617/60x series engine. Why, because the twin cam setup. When they break off its not the end of the world. Mercedes has an extraction kit to get it out ( check out youtube for a vid of the procedure, it's very interesting) But if the kit fails or you fubar it ( you can do it at home with a left hand drill bit and tap but, you have to be perfect!) You will have to take it to a machine shop to be removed or if you dinked up the head, plop down 3k for a new head.
here is the break down
om617 - Durable, tunable( takes some work but proven), but slow compared to the rest... rated 123 hp, 175 ft lbs
om603 and 60x series. A modern diesel engine that puts out a very good amount of power
stay away from the OM603.97. It's a 3.5 version of the 603. All of Mercedes's diesels use cylinder liners instead of a straight up bore into the block. But the 3.5 is sans liners and likes to suffer from bent rods, no one can pinpoint the reason why but every 3.5 is prone to it and if they were not given the upgraded rods they will bend eventually. But the crank from it installed in a 603 will yield a nice stroker motor
om606, the most efficient and modern of the diesel but most complicated electrical wise. also, most expensive if found.
So, if you want to go the diesel route, let me know.
for those interested, I did not cite any source other than personal knowledge ...
06-02-2008, 09:33 PM
#17 (permalink)
I really just don't see myself going with a diesel. I want to stick with a gasoline engine.
06-02-2008, 10:02 PM
#18 (permalink)
Veggiedynamics
I love my 5 cylender turbo diesel in my 300d.. those motors are virtually bullet proof.. there feel semi slow in the benz but then again the bens id 4000 lbs, the dang thing weighs more than my V8 grand Cherokee by almost a quarter ton..
ALways wanted a MB 300d motor in the Grand cherokee.. maybe some day?
07-23-2008, 10:51 PM
#19 (permalink)
Easy Diesel Z swap
Im currently collecting the parts for my swap. So far I have a 81ZX, the engine, harness, intercooler, ecm, cluster, misc spare parts. The Engine is from a 01 engine code ALH 1.9l TDI. Im planning on having the ecm re flashed to eliminate the immobilizer and egr program. Eliminating the immobilizer means you don't need a VW key, reader coil or instrument cluster. Eliminating the egr program allows you to remove the egr valve, egr cooler and solenoid valve. The biggest benefit by removing the egr is not having the intake manifold plug up with carbon (very common tdi problem)
What I need to complete the swap;
Acme Adapters, adapter plate
Toyota 22r 5spd transmission
Custom drive line
Fuel Mods (Pump, lines, cooler)
Motor Mounts
Exhaust
Time and Money
I dont think the swap will be that difficult, once the engine bay is stripped and the mounts are correct then everything should bolt right in, plenty of room for intercooler piping, fuel filters, ect.
I think your fuel economy with the vw tdi would honestly bring you 60-70 mpg on the freeway, Ive been on Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community for a while and have seen people getting as much as 65 mpg in a 3000lb+ Jetta!
2100lb hypermiled tdi 240ZG  60, 70, 80mpg???
Mix a little propane in there to increase the combustion efficiency and a fuel/air separator, probably see another 10mpg
07-24-2008, 01:58 PM
#20 (permalink)
4-banger Z-car
I can't tell you how much in favor I am to your project.I'd considered putting a 16-HP, V-twin riding mower engine, into a Corvette for a Sierra Club TV show back in the 90s.It wasn't to be a road car,just to point out to viewers,how little horsepower the car actually needed for daily driving.The Z-cars (all of them) are still quite advanced,and would make great platforms for ecomodding.I'm useless to you with respect to engine candidates.Sorry! I'd be tempted to pull the guts out of a '93 toyota pickup and shoehorn it in.It's not OBD-2 and its not all-aluminum,but it is EFI,they can get in the 30s as a truck,and have a pretty flat torque curve and plenty of grunt.A neighbor did the Chevy 350 swap into a Z-car.He no longer owns the car.That may say something about how rewarding that project was for him.Also,Bo Jones,a local hot-rodder,in Woodland Hills,Ca.,where I grew up,had a favorite car,a T-bucket roadster with a little Iron-Duke I-4 power.The thing was so light.he could embarrass the hell out of a lot of muscle-car owners.He new power-to-weight and used it to his advantage.And in spite of the terrible aerodynamics,the little hot rod put other cars to shame at the gas pump.I think,with modest power,you could still have a ball slinging her through the S-curves,and have no guilt at the pump.It's your call.I'd love to see you do it.
