Old 09-09-2011, 07:08 AM   #1 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
POD Filter - good or bad?
How does a POD work - Hardtuned.net
I was reading that after curiously thinking about a pod filter.
A cold air intake would cause the car to use more fuel right?
What about air restriction - less restriction = more air, but won't it introduce more fuel to get the magical 14.7:1 ratio ?
Is there any FE benefit in a pod filter (instead of a WAI)?
Old 09-09-2011, 08:11 AM   #2 (permalink)
To keep the answer short and simple, a pod or high flow OEM replacement won't help or hurt fuel economy at all.
Old 09-09-2011, 09:07 AM   #3 (permalink)
A pod filter will do more harm than good in my experience. Air boxes are tuned for flow and resonance, and replacing them with a pod filter will hurt your throttle response and mid-range torque - costing mpg.
At WOT it may give you slightly more power, but it will hurt performance and MPG everywhere else.
Washable replacement filters like K&N aren't any benefit either from what I've seen, and usually don't filter as well as OEM-style pleated paper.
Old 09-09-2011, 09:16 AM   #4 (permalink)
The PRC.
One of the site's creators did a test and found no difference. You may get improvements on a tuned engine but as a direct replacement for OEM save your money.
