Old 04-22-2023, 11:53 AM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
A/C Condenser airflow needs - full grille block
How do you guys handle the cooling needs of the air conditioner when you have a full grille block ?
How can you tell if the size of your opening is too small ?
From what I have read, when the condenser is clogged, your A/C just won't cool well.
That seems like an easy indicator, except that I have read that if you put too much stress on the A/C, it could blow the seals.
I live in Texas. A/C is mandatory for life.
Old 04-24-2023, 02:47 AM   #2 (permalink)
Maybe trying some NACA ducts?
Old 04-24-2023, 11:25 AM   #3 (permalink)
'A/C'
1) air flow to the coil would be a requirement. Walter Korff, of Lockheed Aircraft Corporation provided inlet and ducting geometry parameters for us in 1963. It's in my photo-albums somewhere.
2) a non-aspirated, heat-conductive 'panel', in which the 'coil' is thermally-bonded to the inside, as part of the belly,could serve the same function, with zero drag penalty ( ISUZU 'Glider' technology ).
Old 04-24-2023, 12:22 PM   #4 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
The short answer is open up your grill and look for aero gains elsewhere.
I find A/C to be a pretty large hit to mpg. I would not do anything to make the A/C system work harder.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 04-24-2023, 01:10 PM   #5 (permalink)
I wonder if the metamaterial to radiate into the darkenss of space will be applied as a vinyl film?
Skin radiators might make a comeback.
Old 04-24-2023, 03:04 PM   #6 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Measuring radiator flow.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 04-24-2023, 04:21 PM   #7 (permalink)
Curiously, AmateurAerodynamics chose the same vehicles as you.
[Bookmarked.]
Old 04-24-2023, 06:04 PM   #8 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
i turn the ac on with max heat in the winter because its so rainy and humid here. if you dont, youll fog up inside. i had full grill block and no issues. then again, i was trying to provide heat in the winter, versus cooling in the summer
Old 04-29-2023, 01:03 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
In my previous P307 I had powerlock motors to open the grille block.
Old 04-29-2023, 03:07 AM   #10 (permalink)
That would be a good setup, yet finding some way to set a safety temperature to make it open automatically to prevent overheating is desirable.
