Old 11-08-2008, 03:28 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Driving in wind vs. calm: which is more efficient and why?
What's more efficient and why: driving a round trip in calm conditions, or driving into a headwind at higher load, then in the tailwind on the return trip?
Thanks for the thoughts,
Old 11-08-2008, 07:01 PM   #2 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
My thoughts are that calm would be better. Because the amount of work to power through the wind goes up exponentially as the speed increases. So the headwind (essentially higher wind speed) would hurt more than the gains youd get from a tailwind (essentially lower wind speed).
Winter daily driver, parked most days right now
Summer daily driver
Old 11-08-2008, 11:11 PM   #3 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
IF the gale was strong enough to put your vehicle's engine into an ideal load condition; i.e.-that elusive BSFC map island...
AND you could coast all the way home...
essentially a mega pulse and glide, then yeah, it would be more efficient.
In other words, I think calm conditions would win. Darn fickle Mother Nature...
-Terry
Old 11-09-2008, 06:57 AM   #4 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Calm. Most of the time you're not getting a pure head or tail wind and there is some crosswind component. The more of a crosswind vector you get, the more of a side load you're putting on your tires (the equivalent of light cornering with its increased RR) and vehicles typically have much worse Cd for a wind coming in at an angle than they do for a wind coming from straight ahead (increased aero drag). Then there's the exponential wind velocity factor mentioned above. But even if you drop your ground speed to compensate for the increased airspeed during the headwind portion of your drive and increase your groundspeed while driving in a tailwind, the crosswinds and gusts are still going to increase your RR and aero drag.
aerocivic.com
Old 11-09-2008, 11:03 AM   #5 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
I'm not convinced that would be beneficial...
BSFC islands show you the best thermally efficient zones - but that doesn't mean it won't consume less fuel.
If riding in a headwind puts you into peak BSFC, you're using the least amount of fuel per HP... But, if you need to make 15hp more to be on that island, that could very well mean you're consuming more fuel, just at a higher thermal efficiency.
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 11-10-2008, 09:17 AM   #6 (permalink)
Doesn't your frontal area increase in a crosswind? The 'front' of your car is relative to the wind vector, not the vehicle's direction down the road.
Old 11-10-2008, 03:23 PM   #7 (permalink)
90 day: 51.82 mpg (US)
aspera: yes.
A goes up for sure; Cd probably does too.
Old 11-10-2008, 07:31 PM   #8 (permalink)
Disturbed air might come as a tailwind, in which case drag would be lower.
