Old 02-04-2016, 09:04 PM   #1 (permalink)
Question Beare head 2.0?
I am currently designing a new and improved version of the beare head motor.
The following specs were claimed by Michael Beare:
40% more fuel economical than a 4 stroke,
9% power increase.
However i notice it can do WAY more than this.
The six stroke engine takes the power of the crankshaft spinning three over the other one spinning once 3:1 ratio. To me this causes a power "tension" meaning there can be so much more power if it is given the oportunity.
I am taking the power from the lowest rpm crank to give it a great torque rating (which helps with vehicle load in my opinion) AND the faster crank helps drive the lower rpm crank. Giving it over 33% more power.
I have some issues however, in order to make it a feasible, beastie motor. I need to know if i can get away with reed valves on both intake and exhaust, a valve system, or i can try another approach (maybe a tesla one way valve?), Second, how tight do i need to make the bolts so that both crank cases fit properly? Third is about Direct Injection or carburretor fed.
There are theoretical equations that make this new design more powerful. Like Gasoline motors have the capability to run diesel applications, and diesel versions? Got one hell of a torque buster, fuel savin ravin beast!
As i am a learning and growing gearhead, i am asking your help because all i see is specs and not the knowledge behind it all.
Old 02-04-2016, 09:47 PM   #2 (permalink)
You won't find much in your research until you look for MALCOLM Beare.
I don't know where you get the 3:1 crankshafts ratio. It's 2:1.
I'm no engine engineer but I don't think there are any reed valves that withstand exhaust heat.
Look up the difference between power and torque.
Beare's been playing with it about 20 years now. It's gonna be a long road.
Xist (02-05-2016)
Old 02-05-2016, 09:33 PM   #3 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I'm pretty sure extra weight flopping around isn't going to make an engine run smoother. Buyers are woefully unimpressed by fuel economy, but they sure do complain when their engine feels rough. For a long time that was a really strong selling point for straight sixes.
I think such concepts as the Crower Six Stroke are a better approach, taking the cooling effect of the water and appropriating its steam expansion for power production.
The Following User Says Thank You to elhigh For This Useful Post:
Logic (04-19-2025)
Old 04-19-2025, 07:03 AM   #4 (permalink)
If you want a smooth engine; nothing impressed me like adding Boric Acid (yes ACID ) to the engine oil of cars!
The resulting 'refined' smoothness has to be experienced to be believed and believing seems to be the BIG issue, like there aren't any old smokey, pre rebuild engines in existence to test on...
The er... debate starts around here.
The Crower Six Stroke now has huge potential, thx to Koenigsegg's FreeValve tech, where the cam design and very steep valve ramp angles with 1/3rd speed cams was a rpm limiting issue in the original.
Here's a guy running on his own DIY freevalve system.
diesel, gasoline, six-stroke
