Old 06-04-2019, 08:59 AM   #31 (permalink)
Ecomodding Apprentice
The Following User Says Thank You to Nathan jones For This Useful Post:
TexasCotton (05-10-2020)
Old 06-04-2019, 09:00 AM   #32 (permalink)
[IMG] upload[/IMG]
Old 06-04-2019, 09:07 AM   #33 (permalink)
[IMG] upload[/IMG]
Not everything, posting pictures is difficult. Moulding replaces spoiler too. Also made some carbon pillar supports for the plastic windows. Hovering around 100 mpg (26c ambient). Will crack on with bonnet/wings/bumpers in the autumn when I have more time
Glass/spoiler 8.35kg
Carbon 2.05kg
Quarters and the narrow smoked glass will be done next week. Will make a poly viewing slot
n.b Im getting used to carbon, I made a pillar support for underneath and its more rigid than needed so I recon 300g could have been shaved off with selective reinforce points
More rigid than the glass incidentally!!!
Need a better website with cut paste photo upload
Old 06-04-2019, 09:11 AM   #34 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
You should be able to attach images directly when posting. Alternatively, I use imgur for hosting and put img brackets around a direct link to the image.
Xist (08-26-2019)
Old 06-04-2019, 09:24 AM   #35 (permalink)
I can't do it and imagegur takes ages. I'll do more in batches next time. Thanks
Well they worked yesterday and I cant see a way to attach pictures
Oh...thanks its in advanced??
The Following 2 Users Say Thank You to Nathan jones For This Useful Post:
Coreyosaur (12-20-2019), TexasCotton (05-10-2020)
Old 06-04-2019, 09:36 AM   #36 (permalink)
Unfortunately none of your images work for me.
Old 06-05-2019, 03:57 PM   #37 (permalink)
Heres some it's still taking ages as the pictures are on my phone
Theres a pillar underneath I made from casting a hoover pipe on the back of the glass, it strenthens but might have been overkill
Also the bits are where the wind blew while I was indoors and leaves and tree bits landed on it and wont come out
ID:	26107   Click image for larger version
ID:	26108   Click image for larger version
Old 06-05-2019, 04:03 PM   #38 (permalink)
All done, its easier to make carbon fiber than post pictures. The tape it just to hold it down while the panel bond goes off. Ive ordered enough stuff to do the front end. Getting it sprayed will be the most expensive part
The lines are where the sheets are folded in the post, you can get it rolled but more expensive...
Ecky (06-05-2019), TexasCotton (06-05-2019)
Old 06-05-2019, 05:41 PM   #39 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Are you replacing the back glass with carbon fiber?
Old 06-06-2019, 05:02 PM   #40 (permalink)
Hi, yes it replaces the rear glass and spoiler and light. The boot only needs one lift strut too now. I really want to replace the smoked glass section too at some point
..I plan to do the quarter lights next week, according to calculations they weigh altogether 1.6kg, the carbon fibre will weigh 210g. I can use quite thinner layers as it's narrower support distances. After the glasses it becomes quite difficult to reduce weight
