Old 06-21-2010, 03:10 PM   #1 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Prius Hot-water bottle
Not sure if this where I should be asking this but... Does anyone have the part numbers for the Prius hot coolant storage tank and diagrams on how it is ran?
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 06-22-2010, 02:49 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Maybe not exactly an answer, but here are two threads that might be worth reading.
Keeping Engine Coolant Hot
Mimicking Gen3 Prius Exhaust Heat Recovery
Old 06-23-2010, 11:48 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I went to look it up for you, but the Toyota parts sites I've looked at in the past don't seem to have the prius.
Anyway, the best way to find that information is to check a shop manual or a parts site. Or you could even call up toyota and ask them or go into a dealership. The guys at my honda dealership are very nice and will always help me out with that sort of request.
Furthermore, I think the tank set up is pretty simply, just a tank with three lines, one in, one out, and one on some sort of control solenoid, IIRC.
Old 06-24-2010, 07:41 AM   #4 (permalink)
Over $1000 from Toyota.
regards
Mech
Old 06-24-2010, 07:49 AM   #5 (permalink)
Yeah just the bottle is expensive. They're a couple hundred even from salvage yards.
The Following User Says Thank You to Daox For This Useful Post:
TexasCotton (07-04-2010)
Old 06-24-2010, 10:15 AM   #6 (permalink)
Just modify a small water heater. Cheaper and you'll get a crankcase heater as well.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 07-04-2010, 11:30 AM   #7 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Not that your idea is okay. However the Gen 2 Toyota Prius aluminun heat recovery coolant storage tank is design to fit a very tight spot near driver side left engine bay. Doax is right either source thru reliable used parts dealer, toyota zone website, and or local toyota parts counter..
Old 07-06-2010, 03:21 PM   #8 (permalink)
Phantom's Avatar
If I see one at a junk yard I will just say its a coolant overflow tank LOL.
Does anyone have a diagram of how its plumed an how the wiring is ran.
I figure that with a few controlled valves I could place it after my cars water pump at the elbow that runs to the Lower Intake Manifold allowing me to open the tank when starting using the pump to push the coolant out. Then close the tank and circulate the exiting coolant from two tees with one way valves in/after them allowing me to fill it with hot coolant. Or something along those lines but I'm not exactly sure how the Prius runs the system.
Old 07-07-2010, 08:15 AM   #9 (permalink)
I know the system isn't incredibly simple. It has a temp sensor in the thermos to know when to open it up and when to keep it shut. It also uses a three way valve that controls when and where the coolant goes. At one point I had found or seen something about how it operated. However, I can't seem to find it now.
Old 07-07-2010, 10:56 AM   #10 (permalink)
Gen II Prianista
Rokeby's Avatar
Discussion /drawings of the Gen II ICE coolant system/thermos tank begins on
pg. 4-8 in this document.
Sorry, don't know the Toyota OEM part number.
The "reserve tank" goes for ~$785 at this Internet site.
Hope this helps.
Prius fatal accident rate bwilson4web Hybrids 22 02-05-2010 11:23 PM
DIY Solar Hot Water Heat Exchanger bennelson Saving@Home 3 09-17-2009 09:33 PM
Hot water! The Atomic Ass Saving@Home 18 04-16-2009 12:00 AM
PEX solar hot water collector Daox Saving@Home 7 10-11-2008 10:18 AM
Hot water from oil in the summer time. Xringer Saving@Home 11 09-06-2008 10:02 PM
