Old 04-24-2013, 02:52 PM   #21 (permalink)
I mathed out a trike conversion on a Tempo. Modest lowering and increasing front track via offset wheels lead to predicted stability no worse than that of a full-size van.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
aerohead (07-13-2013), Smurf (04-24-2013)
Old 04-24-2013, 07:36 PM   #22 (permalink)
Originally Posted by elhigh View Post
... the rear suspension of any largish touring bike has enough oomph to hold up the light end of a tadpole trike.
Yeah, it'll hold up the static weight, but I wouldn't trust it in stock form for cornering, as it was never made to handle significant SIDE loading.
Old 04-26-2013, 05:40 AM   #23 (permalink)
Just a thought, but since you're taking a great whack out of the vehicle anyway; if you pie-cut the floorboard just inside each door (even 2 or 3 inches), you could move the door post in and start the side taper 3-4 feet sooner.
Are you going to chop the top?
Old 04-27-2013, 08:24 AM   #24 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Good point. Can't lean into the turns anymore to keep the loading lined up with the bike's centerline.
But then I think about such classic tadpoles as the Tri-Magnum and other kits that made use of a big bike's rear. Did they add any kind of bracing to bolster the rear? I honestly can't remember right now.
Old 07-13-2013, 03:04 PM   #25 (permalink)
drag number
Originally Posted by HydroJim View Post
smurf- I think it will end up being lengthened a little bit, but not too much. I'm trying to keep the weight down. I think front wheel skirts can achieve a similar drag number with much less frontal area. I like the fiberglassing idea, but what is on these right now is well and working so I think I'll stick with it. Keep the ideas coming though.
albyneau- The guy who assembled the fastener kits did it because he was using them on his turbo build. a few guys on the forum asked him to put together some kits. He did it and sold it at cost to a few guys on the forum. One of the guys ended up liquidating all the parts that he was saving up for the build and I scored the fasteners for cheap enough to justify the price. I believe the whole kit was 168 pieces and it cost about $1 per piece originally. So I'd say the pricing matches your 2-4 per bolt. The guys have been using the hardware no problem. I thank you for your advice though!
Apologize for late catch up.
Your doing exactly as Hucho recommends.
Kamm achieved Cd 0.12 in 1/5-scale model @110 mph tunnel speed with full-'Template.'
We know from Walter Lay's research at the University of Michigan that morphing the 'pumpkin seed' nose into a more conventional A-Pillar/windshield makes no dent in the Cd.
You have a real good shot at Cd 0.16.
Old 07-13-2013, 03:30 PM   #26 (permalink)
trike
Korff did a reverse-trike.Very stable.
I think Tri-Magnum guys did an exhaustive study on chassis dynamics and showed good numbers.
Dymaxion Car was struck by a rubber-necker so that one doesn't count.
GM brought the Messerschmitt over for the Cadillac dealerships in the '50s.A room mate's girlfriend's older sister's boyfriend had a Messerschmitt and he drove it like a mad man to no ill effect.
Volkswagen did a really nice reverse-trike in the '80s.
With FWD the Metro has a CG advantage like Citroens of the 70s.
Kamm stayed with DKW as it was the only FWD offered in Germany.One of his last streamliners was a 1960s DKW for Battelle Institute,Frankfurt.
And Kamm was almost obsessed with directional stability.
I don't see a big problem.
Old 09-19-2013, 09:17 PM   #27 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
This project has been resurrected. My dad has got himself together financially and I think he's itching for one last project before I go off to college. I'm thinking of doing this whole thing over 2 weeks of Christmas break. If I finish it on time, one last science fair for me, and if not, I'll just finish it up later no big deal.
That sounds crazy, but I think I can do it. You'll know for sure in 4 months. Time to refresh myself on the details and start getting a plan and a budget going.
Old Mechanic and I might have ourselves a little competition going soon.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
Xist (09-19-2013)
